Question on L92 to 4L80E
Old Dec 12, 2007 | 02:14 AM
Soundsgood's Avatar
Default Question on L92 to 4L80E
I want to match a L92 to a 4L80E but the flex plate that came with the engine has a strange hole configuration (not 6 bolt as per converter). Can anyone point me in the right direction.
Also, I can't find the part number for the fly by wire pedal, will a Holden FBW work?
Thanks
Bruce
Old Dec 12, 2007 | 10:27 AM
N4cer's Avatar
Should have 3 bolts.
Old Dec 14, 2007 | 09:53 AM
jason99frc's Avatar
Weaker converters have 3, Bigger better converters have 6.
Old Dec 14, 2007 | 10:44 AM
N4cer's Avatar
Um, yeah good point. I have a PY3600. If you read, my response was regarding the thread, where he's asking about the stock flexplate bolt pattern.
Old Dec 14, 2007 | 10:52 AM
Bill Reid's Avatar
Old Dec 14, 2007 | 01:39 PM
LC's Avatar
LC
i guess my ati5500 is weak
Old Dec 14, 2007 | 02:12 PM
jason99frc's Avatar
Im not saying that in a bad way, but your "better" converters built to handle big hp are USUALLY 6 bolt.
Look at every SFI FLEX PLATE, it has mounting for 6 bolt converters NOT JUST 3.
Bill Reid - Roll your eyes when you leave the line and you have a bolt failure, the converter shifts because there are only 2 bolts holding the converter and wipes out the front pump seal and fluid dumps all over the rear tires and you eat the wall.
Old Dec 14, 2007 | 06:08 PM
Bill Reid's Avatar
My 3 bolt Vig for my 4L80E is gonna do me just fine... I'll never be at a power even remotely necessary for a 6 bolt... IMO, neither would most on this forum. If one uses good SFI approved parts and hardened hardware the chances are even more remote. Your comment, to put it nicely, is/was a little too generalized... hence the Don't sweat it... I'm not
Bill
Old Dec 15, 2007 | 07:25 PM
BigBlue95Z's Avatar
Need to get a different flexplate. Need to find one off of a truck 6.0 that had a 80 from the factory. I'm not positive on the exact one though.
Old Dec 15, 2007 | 08:47 PM
Gm-LSX's Avatar
Use
PN 12551367 Flexplate (1x) $88.98
PN 12563532 Spacer (1X) $29.59
PN 12563533 Bolt (6x) $3.88 = 21.96
_______________________________
$140.53
www.gmpartsdirect.com (i hope they are somewhere to the right)
Old Dec 15, 2007 | 09:48 PM
N4cer's Avatar
My Yank converter was made to go from an LS1 flexplate to a 4L80e tranny. Works great with a stock flexplate. If the LS1 flexplate will work for ya, I am getting rid of my stock one, after just 3 months of use. Switched to a TCI.
Old Dec 17, 2007 | 01:09 AM
Soundsgood's Avatar
Originally Posted by Gm-LSX
Use
$140.53
Thanks, that's what I was looking for.
