418
Old Jan 15, 2008 | 11:41 PM
C5 Forever's Avatar
Default 418
Who has one? What does your set up look like? What is a big cam that works well with nitrous?
Old Jan 17, 2008 | 09:50 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
We've done tons of the 418 short-blocks with great results. I personally like the 251/259 camshaft, but we've also put together a 248/256 camshaft on a 114 that would work really well with a little bottle behind it...
Old Jan 17, 2008 | 01:58 PM
C5 Forever's Avatar
I had read a little about the 251/259; people seem to like it. I know you guys like the PRC L92 heads. Have you seen any 418s with the TFS 235's or 245"s; what did you think? How about the PRC LS7 heads? Any with the above mentioned cams?
Old Jan 17, 2008 | 09:59 PM
Bring the Noise's Avatar
Will the LS7 heads even work on the L92 blocks? IE Valve clearance...
Old Jan 18, 2008 | 07:01 AM
Shawn @ VA Speed's Avatar
the ls7 valve will clear the bore by .050,but i dont think they would flow too well,lots of shrouding
Old Jan 18, 2008 | 07:59 AM
fastvet's Avatar
your 251/259 cam, what lift And lobe is it? What type of power did it put to the wheels N/A? I am thinking of getting one, but dont know what cam.
Old Jan 18, 2008 | 02:15 PM
Randy WS6's Avatar
I have a Crane Cam in my 418cid. 250/266-651/651-112 but my displacement is a little differant than Texas Speed ,Mine is a LS2 4.030 bore & 4.100 stroke i dont know if that makes any differance, But i love the way the cam pull on top end and with nitrous.
Old Jan 22, 2008 | 06:33 AM
fastvet's Avatar
Thats awesome, what times are you getting, and with what tire size?
Old Jan 22, 2008 | 08:16 AM
Randy WS6's Avatar
No times yet, 4:30 gears and 315/35/17 tires ,The motor is real strong and massive low end and mid range
Old Jan 22, 2008 | 12:32 PM
JoeyGC5's Avatar
LME complete 416 L92 setup, 530hp/518tq on 28 degrees timing with a 244/254/112 cam.I keep wanting to put the bottle on to chase some liter bikes down, but I'll need a major fuel upgrade or a standalone from what I have now.
Old Jan 22, 2008 | 01:11 PM
Zach@MTI's Avatar
https://ls1tech.com/forums/dynamometer-results-comparisons/818119-mti-416cid-stroker-dyno-results.html
