LS3 hollow stem intake valves.....
Old Jan 29, 2008 | 09:07 AM
1.8t's Avatar
Default LS3 hollow stem intake valves.....
Did some searching, but the results still seem a bit unlcear. With regards to durability, how are these valves? In searching this site, it appeared that the stock valves were fine for n/a applications, however for F/I and Nitrous applications, apparently they were not the application of choice. Reason I am asking is because I have heard of C5Z's breaking the valve off the stem before due to the 2 piece welded design. I am worried about cam'ing my LS3 because of the higher seat pressure from aftermarket valve springs. All this would do is exacerbate this potential weakness and induce failure that much more quickly. That said, what do you guru's know about these valves? Is the construction process the same as the C5Z's valves? Have you guys ever heard of the C5Z's breaking their hollow stem valves? If these valves are crap, I will yank the heads and put new ones in along w/ a CNC job when I decide to cam the car. Optimally, I would just like to cam it and be done but that 2 piece welded design has me worried.
Old Jan 29, 2008 | 11:06 AM
black_z's Avatar
I wouldn't worry about it for an NA application. Cylinder pressure is quite low compared to a boosted or sprayed application.
Old Jan 29, 2008 | 11:08 AM
Richard@WCCH's Avatar
You're correct about the hollow valves handling NA duty. They don't play well with FI applications though. The factory valves are well built, but very thin in critical areas. We've not seen any failures in NA engines........yet.
One thing you can do to minimize the hammering on the valves is to choose lazy cam lobes. The performance loss is minimal and valve train stability stays high. The heads will carry nice hp due to the large high flowing intake ports.
Good luck,
Richard
Old Jan 29, 2008 | 11:50 AM
1.8t's Avatar
Good deal, I really appreciate the help guys. Richard, can you give me some examples of some cams with some gradual ramp rates?
Old Jan 29, 2008 | 02:52 PM
Ragtop 99's Avatar
Comp XE lobes are relatively mild, at least in comparison with their XER, XFI, or LSK lobes.
Old Jan 29, 2008 | 07:08 PM
See5's Avatar
We use them with PSI 1511 behives with great success. The valves only weigh 89 grams vs 108 for L92 intake valve.
Old Jan 29, 2008 | 07:09 PM
Excellent point. Comp has a number of lobes listed in their master catalogue that they can girnd onto a LS cam core. You'll need to check with them when ordering.
Richard
Old Dec 19, 2012 | 07:14 AM
GIGAPUNK's Avatar
I'm purposely bringing this back from the dead. Richard, 4 years latter have you still not seen an N/A Stock LS3 intake valve failure on a cammed car?
Old Dec 19, 2012 | 07:00 PM
ohiomike's Avatar
wtt my l99 non hollow valves for your hollow valves
25k miles
I am ls3'ing my L99.
Old Dec 19, 2012 | 07:52 PM
litle88's Avatar
25k miles
Go for it! Money well spent!
Old Dec 19, 2012 | 07:55 PM
litle88's Avatar
Not that I'm aware of sir, mods in my sig and I know a few others that have some sort of similar setup and no breakage (yet) knock on wood lol
