Best engine for a DD?
Im currently in afghanistan but I got a 99 SS for when i get back and have plenty of money for some upgrades. I am gonna get an s60/ suspension/ headers/ ls7 clutch, but I dont know what would be the best engine for a daily driver with like 500rwhp..here is the 3 im looking at
Scoggin dickey complete el toro L92 427
a 402/l92heads/l72 intake
or a 402/ TFS or afr heads/fast 90/90
i have heard the stroke is a little to long for a dd for the l92 427 but besides that any help would be greatly appreciated
I don't drive mine every day, but a few times per week I will drive it to work. Its not too bad on gas if you stay out of boost. If you do that much work work to your engine you are going to have a serious guzzler. I guess it all depends on how much daily driving you will be doing. Will you have a long commute?
I don't drive mine every day, but a few times per week I will drive it to work. Its not too bad on gas if you stay out of boost. If you do that much work work to your engine you are going to have a serious guzzler. I guess it all depends on how much daily driving you will be doing. Will you have a long commute?Trending Topics
Im looking at like a 15 mile commute to work and school, so yeah gas is kind of an issue.
any suggestions would be great
Complete build info here: (long but interesting)
https://ls1tech.com/forums/generation-iv-internal-engine/662314-l92-dynojet-numbers-plus-plan-b-c-d-e-f.html
Just so you know, "Plenty" of money can disappear very, very quickly when doing this ****
EDIT plus LS1 f-bodies don’t have many options that are not centrifuge style chargers which is good when it comes to mileage because the boost comes on much higher up in the rpm range
As far as the engine goes, im open to anything. I just what ones with a decent cam, good idle, and it would be nice to have mileage around 20mpg on the highway. But even in my old lt1 Z M6 id only get like 22-23 on the highway with only bolt ons
BTW i have like 35k in the bank from this 15month deployment so im set on money for now, i think ive earned a little present for myself lol
224/228 cam, afr/tfs heads, fast92/92 and you should be mid/high 400's anyway.
Also is ther much point buying a new engine if you want a new car? Unless you are going to swap them over I guess. In which case go the 402
Not at 11.3 that I'm running now.
I average about 15MPG driving any damn way I please.
About 20-21 cruising on tripsBTW i have like 35k in the bank from this 15month deployment so im set on money for now, i think ive earned a little present for myself lol
You've definitely earned that and more. I've got about 12k in my build but that includes replacing my 1 3/4 LT's with 1 7/8 AR LT's, a $1200 clutch, etc, etc, etc.
PM me for a ph number if you want to talk about it. If you read all of that post, I have no secrets in this build - yet.
BTW: The little bit of extra bore in the L92 block over the LS2 block is important and unshrouds the exhaust valve.
thanks again and good luck.
I was looking into heads/cam headers/ 90/90 too but I dunno if i wanna do it on the stock shortblock especially the rods/bolts I know thats a weak point. If i do those i may as well do a rotating assembly, and by the time i get the block preped bored, honed, it would be easier and about the same price as a 402 shortblock...so thats where i am right now.I already have a ported fast 90/90, some suspension and a magnaflow from when i was on leave and I pretty much had the deal and the seller backed out at the last minute.
Basically i just want something that will be reliable, and fuel mileage is decent...so keep the suggestions coming!
thanks
