Anyone used 5.3 heads with a torquer v2?
if youre using this in a LS1
#1 your in the wrong section, post in the LS1 section
#2 yes , even if its the 5.3 stage 2.5s from TSP, but only if you use the non cosmetic gaskets, so I tink .060" or something, it should be fine, but ask someone else to be sure..
LS1Tech Premium Sponsor
We use our bigger valve stg 2.5 5.3l heads all the time with torquer camshafts. We can set it up with a little bit of decking specific to that camshaft!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
There wouldnt be any flycutting involved???
Yea sorry bout that I thought i posted that up in a genIII forum
I doubt springs have anything to do with it clearing, unless you use weak springs and they float the valve, then your piston can slap the valve...
