400+ cid What cam
From what i saw and how the car felt, i really liked that cam for that size motor, so looking for something similar for a bigger cid. I appreciate any input, Thanks
The Blue lines are AFR heads with a 242/248 cam.
The Red lines are Dart heads with an excellent Valve Job and a smaller cam. No, I can't tell you the cam specs.
Heads have a lot to do with how much cam you need, or don't need.
Thanks for everyones input, just trying to get a rough idea one what people are running in bigger motors.
I have an idea from talking to ppl what kind of #s Ill make
with some light weight reduction, but getting a rollcage installed Ill be back at a stock weight hardtop m6 Z28 (2002)
I believe I should be making a ballapark area of over 470rwhp (hopefully) and none less.. if things go well I could make over 480rwhp, who knows...
I also think with slicks, 3.73 rearend (m6) I should still break in the 10s NA...
Ill keep you posted.. if I forget, remind me...
http://videos.streetfire.net/video/syns-408_166314.htm
http://s155.photobucket.com/albums/s...t=MVI_0170.flv
Comp Cams 244/244 .598/.598 114
TEA AFR Stage 3 heads
My numbers are 520rwhp/500rwtq
It's a very drivable set-up. The build was for a fast street car with plenty of power under the curve. I can drive the car in bumper to bumper Atlanta traffic with the AC on with no problems.
