510cid small block
Old Jun 25, 2008 | 12:55 PM
Domexitium's Avatar
Default 510cid small block
If i'm doing my math right, the LSX block with a 4.250bore X 4.500 stroke would yield 510 cubes. Is that even do able? If that was the case we could easily be looking at a 700plus RWHP NA pump gas LSX. I don't know, would that type of stroke compromise the block?
Old Jun 25, 2008 | 01:05 PM
Phil99vette's Avatar
7 Second Club
Why would you do that when you can make more hp for less money with a FI setup? Heads and an intake that support a 510cube motor aren't going to be cheap. You really need a set of canted valve heads and a sheetmetal intake.
Old Jun 25, 2008 | 01:09 PM
Domexitium's Avatar
I know what your saying about FI, but I like some people like NA. besides, would it really be that much more expensive?
Old Jun 25, 2008 | 01:20 PM
Ericbigmac83's Avatar
You have to get the taller decked lsx for that, but yes
Old Jun 25, 2008 | 01:22 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
custom rods, cutom crank, tall deck warhawk block, C5r/Canted Valve heads, custom intake valvetrain, custom headers......
yeah you are looking at a 30k motor if not more.
You can put a Injected bigblock in the car for less.
Old Jun 25, 2008 | 01:25 PM
7 Second Club
Yeah the heads alone are around 6k. If you get the standard run of the mill LS1 heads you'll be sorry in the long run, the heads/cam package is what makes the motor sing.
Old Jun 25, 2008 | 01:27 PM
venom ws7's Avatar
The Intake and TB alone will cost $3000+
It will be a sick setup but very very pricey.
I cant imagine 700rwhp N/A LSX with 300shot on top of it SICKNESS.
Old Jun 25, 2008 | 01:30 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
Originally Posted by venom ws7
The Intake and TB alone will cost $2500+
all it would do is fizzle, supporting a 4.5" stroke even on a talldeck block is going to leave next to nothing for a ringland, and 4.250 bore would mean almost no material left on the sleeve, i dont see the motor living very long between rebuilds and at 4.250 bore you would need a new block every time.
Old Jun 25, 2008 | 01:56 PM
Stang's Bane's Avatar
The bigger problem would be sealing it. You would have almost no head gasket in between the cylinders.
Old Jun 25, 2008 | 02:42 PM
Big Bird WS6's Avatar
you couldn't spray it.
but on a side note. just to have a 500+ ci small block. we all know that would be bad ***. and you all keep talking about the heads. MTI has used stock ls1 heads for years. even on there 455 goat build. so you telling me that the trick flow 235 or new afr 235 wont flow enough air? bull ****.
Old Jun 25, 2008 | 02:51 PM
slick1851's Avatar
Stop ******* around a build a BIG BLOCK and swap that in for some NA monster power
Old Jun 25, 2008 | 02:52 PM
slick1851's Avatar
You understand you still need to port those heads correct? There still not good enough out of the box for that kind of motor
Old Jun 25, 2008 | 02:56 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
You go ahead and put a 330cfm head on a big block and watch how much power it doesn't make... in order to make power you need air, and 330cfm is not going to properly feed a 500ci motor. sure it may make 500-600hp. Why would anyone spend 20k-30k on a 600whp motor that would peak at 4500-5000rpm?
Old Jun 25, 2008 | 03:33 PM
needadvice's Avatar
You can make almost 700 RWHP (M6) with a safer, reliable 454ci build and the correct top end, for less than 15K.
Sheet metal intake + ported LS7 heads + 105mm TB + no MAF + 2" headers + 12:1 cr + pump gas
There's no way any of the plastic intakes are gonna feed 510ci, let alone 427ci. Even the best heads available today cannot feed 510ci to their potential.
Until there are 450+ cfm heads for the LSx blocks, you're wasting your time building anything bigger than a 434-454ci engine.
When we do have heads that can flow to match 510 cubes, like the big block world does....then we'll be able to make 800-900 RWHP N/A engines too.
And even if you could do a 510ci, why would you want to max it out, all you will have is a constant ticking time bomb under the hood.
Old Jun 25, 2008 | 05:39 PM
Paint_It_Black's Avatar
I kicked around the idea of a big cube LSX block. It could win some money if you were a street racer. You'd beat most any other small block car that "sits" like yours as long as your car was setup right.
Old Jun 25, 2008 | 06:31 PM
Tuner@Straightline's Avatar
We've already seen a 430cui LSX motor make 600+rwhp N/A through a TH350 on our Mustang Dyno with a nitrous set up. . .
Personally, I think you can do it for between $15000-$20000 depending on your head selection and displacement. You run into problems usuing the stock computer going with a 468cui or larger and spinning over 7600rpm, so keep that in mind.
On a side note, we just completed a ECS S/C kit on a 2006 Vette (M6), that made 590rwhp on a stock bottom end on pump gas. It all depends, either way it's going to cost about the same. Ultimately you'll make more power FI, but the price starts going up really quick. Gotta love the law of diminishing returns.
Old Jun 25, 2008 | 06:39 PM
454 LSX 930hp NA @ 8400rpm
http://www.youtube.com/watch?v=e8LjUQzJurs
Some of the build info:
http://www.maxchevy.com/tech/2007/ii_7-lsx-3.html
Old Jun 25, 2008 | 06:58 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
Full blown race motor with almost 1.00" lift
That motor uses lots of GM supplied pieced one of them being one-off c5r heads along with a bunch of other incredibly high priced components, that motor is way beyond the 30K range.
Old Jun 25, 2008 | 07:17 PM
Domexitium's Avatar
Jesus, i didn't think it would be that expensive!
Old Jun 25, 2008 | 08:03 PM
99blancoSS's Avatar
Couple good points. Just because they say you can hog it out to 4.250 doesnt mean it's always a good idea.
We dont go bigger than a 4.185 with our LXS 454 and we dont recommned n2o with it either. We like the 434 for boost and nitrous use.
