ls2 427 / 454 stroker....what heads?
Old Jul 28, 2008 | 03:47 PM
68topls's Avatar
Default ls2 427 / 454 stroker....what heads?
What heads are you guys running on the ls2 427 /454 stroker motors? L92s / LS2a / LS7s? Thanks in advance.....
Old Jul 28, 2008 | 04:48 PM
2000_SS's Avatar
TFS 245's....i had considered the LS7 topend, but you're limited to ported stock intake or sheetmetal. LS1/2/6 style heads have more options, but don't flow like the LS7 heads do.
Old Jul 28, 2008 | 05:28 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We've tested PRC LS7 heads to 750flywheel horsepower on 454 TSP Shortblocks. I don't think there's any comparison to a cathedral port head.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jul 28, 2008 | 05:44 PM
93TAWicked1's Avatar
I think it really depends on what your are looking to accomplish with your motor.... I have silly little stage III TEA 317 heads, that were once considered pretty nice. I don't konw how much it would cost to replicate my setup but it makes great power for a street setup. But I know my engine is running out of air and alot is left on the table. The TFS seem to make great power and if I were to go with something different I think thats what I'd run.
But it really depends on your budget and your goals and what you think you can grow into if needed. JMHO.
Old Jul 28, 2008 | 06:49 PM
68topls's Avatar
Which PRC LS7 head...265 or 280?
Old Jul 28, 2008 | 06:50 PM
Haans249's Avatar
A lot of it depends also on how much cam you want to run. If you don't want to run a huge cam to make the same power, go with the square port stuff, they take much less intake duration then your typical cathedral port head does, thus less overlap, and better driveability etc... But of course that also depends on good your tuner is.
Old Jul 28, 2008 | 08:31 PM
Azrael's Avatar
TFS 245's.
Old Jul 28, 2008 | 08:58 PM
Jeff@TotalPerformanceEng's Avatar
On my Lsx454, I run TFS 245's..
I wouldnt run the LS7 heads on my motor.
Old Jul 28, 2008 | 09:22 PM
Haans249's Avatar
Why is that?
Old Jul 28, 2008 | 09:36 PM
68topls's Avatar
^what he said
Old Jul 28, 2008 | 10:24 PM
needadvice's Avatar
Why wouldn't you want to make more power, and make it easier?
Old Jul 29, 2008 | 01:44 AM
Because I will pick a car with higher average hp and tq, with more power under the curve over a peak hp numbers ANY day of the week.
The highest average HP and TQ wins races, NOT peak hp.
And for the record, its not "Easier" with LS7 heads. Its just a different methodology.
Old Jul 29, 2008 | 07:24 AM
Haans249's Avatar
Well, it all depends on the setup. On some setups, the TFS heads will make more average hp and torque. If you're talking a street setup, this would be better than a high hp/trq number.
But, in racing situations, higher hp/trq number are the ones that will win, because you spend more time in the upper rpms, where you're making the larger numbers.
Plus, the LS7 heads and intake manifold combo have more potential to make power than a cathedral port setup.
Old Jul 29, 2008 | 08:33 AM
WeberRacingEquipment's Avatar
We have had great luck with the Trickflow heads on the bigger cubic inch motors. If you want to spend a good amount more money and go with a LS7 Style setup the WCCH/All Pro LSW heads are one of the best heads you can buy!
Old Jul 31, 2008 | 01:08 PM
Strini SS's Avatar
I'm runnning ETP 255's on my LSX 454...
B
Old Jul 31, 2008 | 03:20 PM
Stang's Bane's Avatar
T4P prepped ls7 heads.
Old Aug 1, 2008 | 06:38 PM
MPM IV's Avatar
I also went with Trick Flow 245s.
Old Aug 2, 2008 | 04:41 PM
zssman's Avatar
Any of you guys have any 1/4 mile times? Curious how fast these combos are going.
Old Aug 4, 2008 | 11:11 AM
SIC LSX's Avatar
guy here with 454ci lsx block with stock out of the box l92 heads,mid size cam, GM intake amd carb running 9's in 1/4
Old Aug 4, 2008 | 12:23 PM
How much nitrous??
