VR1 Racing oil
Old Oct 4, 2008 | 11:43 PM
  #41
flirtnwithdisaster's Avatar
I run the penzoil 5 w 20 in my 6.0 lq9. Full synthetic. Brand new engine. Cranked up with 70 psi cold 55 hot at idle. My engine is clearenced for the 5 w 20. I have had 0 issues except a little valve noise on cold start up. No smoke or blow by from start up. Has anyone else had this success.
Old Oct 5, 2008 | 12:17 AM
  #42
tillery's Avatar
Penzoil has come along way since I started wrenching. But from the fields I work out of and my experiance with it. I wont use it. Just like some with RP or Quaker state and so on. KinderMorgan owns the fields now so I know Penzoil isnt made from that crap. Overall Ive had great success with Valvaline products. I think desiels oils are very strong due to the fact that these powerplants put more stress on oils than our gasoline engines.
Old Oct 7, 2008 | 03:01 PM
  #43
Haans249's Avatar
If you're running synthetic from the get go, then you really are flirtinwithdisaster! You need to run regular motor oil, preferrably stuff with lots of ZDDP additives, otherwise you may run the risk of your rings not seating properly, and you will then start to have oil burning issues. I would recommend VR1, its cheap, its good, and its got all the additives you need. Read through the beginning of the post, and you will get a better idea of what break-in procedure you should go with. Otherwise you run the risk of damaging your motor.
Old Oct 7, 2008 | 07:35 PM
  #44
N4cer's Avatar
But ZDDP prevents wear. During break-in, we WANT wear on the rings.
Old Oct 8, 2008 | 01:45 AM
  #45
Haans249's Avatar
No, you want the rings to seal, not to wear. Even though the ZDDP is an antiwear additive, it helps the rings seal. You've got your information wrong.
Old Oct 8, 2008 | 08:29 AM
  #46
See5's Avatar
The biggest fear in a new engine is cyl wall scuffing due to rough hone which is used to let the rings smooth the bore. Because LS pistons are so short (strokers more so) the piston rocks which can score the bore. The zinc and non synthetic oil seems to the best bet for break-in.
Old Oct 9, 2008 | 03:01 PM
  #47
Jordan S.'s Avatar
I run VR1 40wt in my car. I tried the 30, 40, and 50 wt's they sell. The 40 keeps me right below 40 @ idle, and up aroudn 55 @ redline after it warms up.
Old Oct 9, 2008 | 03:11 PM
  #48
Haans249's Avatar
55 at redline? Are you sure? You want AT LEAST 10psi per 1000 rpm. So, if you're redline is at 6.5K rpms, you want at least 65psi. I would seriously reconsider the weight oil you're using.
Old Oct 9, 2008 | 03:14 PM
  #49
Jordan S.'s Avatar
It'll be alright.
Redline right now I think is around 7. It varies with the outside temp and how hot the car is. 55 is on a hot summer day after being in traffic.
Old Oct 10, 2008 | 03:38 PM
  #50
Haans249's Avatar
It'll be alright.
No really, thats not good at all. You've got some oiling issues, you NEED to run a thicker oil. The oil film will break down quickly when it doesn't have enough pressure, especially at higher rpms. Thats extremely hard on the bearings, unless you're tearing the motor down every season.
What were your bearing clearances?
Old Oct 10, 2008 | 09:44 PM
  #51
LSGunZ28's Avatar
Dont you want thinner oil if oil pressure is low? Also depends on quantity of oil that is being ran 5.5 qt? less? More? 6? 7?
Old Oct 10, 2008 | 10:38 PM
  #52
Blackhawk777's Avatar
That's true to a point, but I believe that he should be ok, provided there's no excessive wear or metal shavings everywhere in the oil. Mine does similar pressure and it's damn near like a brand new car.
Old Oct 11, 2008 | 12:26 AM
  #53
Jordan S.'s Avatar
They were all within spec. It was almost two years ago since I built it so I don't have a clue, and I didn't write them down. 50 wt would put me off the gauge, at the track 40wt probaly puts me around 70 PSI since the motor isnt heat soaked. It'll be alright. If it makes three years service I'm happy, thats not a bad life for the hell this thing sees. Then it will be time to 10/10 and do it again.
The oil has came out clear everytime with nothing but the norm on the magnet.
Old Oct 11, 2008 | 12:29 AM
  #54
Jordan S.'s Avatar
Yea man the only place I've EVER seen that is on this website. All the engines I've seen since I can remember were 40 idle 60 wot and your good.
Old Oct 11, 2008 | 12:30 AM
  #55
Jordan S.'s Avatar
Thinner oil will drop your PSI, thicker oil will raise it.
Old Oct 11, 2008 | 09:32 AM
  #56
Jordan S.'s Avatar
Is the gauge even accurate in these cars?
Old Oct 11, 2008 | 11:17 AM
  #57
Haans249's Avatar
The guage is decently accurate, but of course nothing will beat a properly calibrated mechanical guage. If everything is coming out good, then obviously you're good to go. Also seems like you're changing the oil after every track session, this will also help as the oil doesn't have that much use to break it down. But, the 10psi per 1K rpm is a GENERAL suggestion to keep things safe, and if you're getting 70psi at 7Krpms at the track before its heat soaked, then thats all good! 55 on the otherhand, scary haha.
Old Oct 13, 2008 | 12:36 PM
  #58
3.4camaro's Avatar
why are you putting racing oil in a car that isn't a straight race car? put DD oil in silly.
Old Oct 13, 2008 | 12:56 PM
  #59
Wesmanw02's Avatar
When you change your oil, what do you end up with on the drain plug magnet?? Just curious, because all the times I've changed mine I've had some gray metallic sludge on the magnet.
Old Oct 13, 2008 | 01:03 PM
  #60
Haans249's Avatar
Huh? You obviously didn't read the whole thread. Just because a car isn't a "race car" doesn't mean you can't run "race" motor oil. I have a "race" motor in my non-"race car", Silly lol.
By Brett Foote | 2026-06-04 05:00:17
