Noise after Longtube installed??!!!
Old Oct 10, 2008 | 12:32 PM
chsmith112's Avatar
Default Noise after Longtube installed??!!!
Just installed my LG Pros lastnight and they sound like they will eat your soul!!! but anyway I also hear a squeeking sound, does anyone know what this could be. Is it the lifters I am hearing now or is it something else that is pretty normal or is something wrong with my exhaust. I am almost sure that it is coming from the engine bay. And it's a really fast squeek like something is moving almost. The faster the engine revs the faster the squeeks become.
Old Oct 10, 2008 | 01:02 PM
Red Devil 99''s Avatar
triple check all the clearance all around the pipes. sounds like its rubbing against something IMO. either that or you have a loose clamp.
Old Oct 10, 2008 | 01:03 PM
chsmith112's Avatar
Do you think it might be valve train noise? It almost sounds like a midly squeeky sewing machine. O and I have an 05 C6 vette if that makes any difference.
Old Oct 10, 2008 | 02:13 PM
JakeFusion's Avatar
Super Hulk Smash
Did you do anything to the valvetrain? If not, there have been a few posts about the LGs not sealing properly. They've always fit fantastic, so I wonder if Borla had a bad run recently.
Old Oct 14, 2008 | 09:47 AM
Ben Diss's Avatar
Make sure you didn't overtorque them. I did that and after retorquing correctly, the noise was reduced.
Old Oct 14, 2008 | 10:19 AM
00pooterSS's Avatar
X2 if you didnt do anything to the valvetrain and the only thing you changed is headers then you are just worrying yourself, take a piece of rubber hose, prefer to use a stethescope with metal tip removed for this but either way is fine, stick hose in your ear and go around every primary, primary flange, and collector, if its a leak it you will hear the air sound blow into your ear very clearly. This trick has worked many many times for me and others. This helped a guy the other day on some Kooks headers, if it makes you feel better he had brand new kooks that had a leak at the primary where they missed a weld.
Old Oct 14, 2008 | 11:30 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
^^Good advice. I'd search for exhaust leaks as described above!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Oct 14, 2008 | 11:34 AM
Rvettej's Avatar
Yes Sir, Listen to 00pooterSS because that Kooks guy was me.
Old Oct 14, 2008 | 12:30 PM
00pooterSS's Avatar
LOL hi kooks guy did you find a solution to the weld issue yet?
Old Oct 14, 2008 | 12:44 PM
JayplaySS's Avatar
Moderator
You did tighten the bolts from the center working to the outside correct? I have seen plenty of noise issues by tightening them incorrectly.
Old Oct 14, 2008 | 12:57 PM
00pooterSS's Avatar
Good point
Old Oct 14, 2008 | 01:15 PM
slowformula's Avatar
Definitely check all the bolts again.
Old Oct 16, 2008 | 02:47 AM
00pooterSS's Avatar
updates?
Old Oct 17, 2008 | 06:57 PM
99bowtieZ's Avatar
Well, the longtubes are supposed to make a different sound. On a more serious note check the torque on your bolts and maybe check belt tensioner, it could have become dirty. Or it could be something completely unrelated to the longtubes.
