Generation V External Engine LT1 Bolt-Ons | Intakes | Exhaust | Ignition | Accessories
Controller kits GM vs Speartech
Old 02-26-2017, 04:05 PM
Gen5GTO's Avatar
Default Controller kits GM vs Speartech
I am starting a Gen 5 LT4 install in a 1965 GTO. As far as the gm controller kit 19331517 vs Speartech's kit, which one do you like and why. Also I am using a T400 in the car and would like your opinion on a signal converter to the ECM I would like to keep the cable driven speedo in the car. Thank you in advance.
Old 02-26-2017, 04:26 PM
samckitt's Avatar
Cant speek for the Gen 5 engine, but I like the GMPP LS3 controller kit I have. All fuses and relays are in a Delphi fuse box, and was easy to supply a single wire for 12 V+ power to feed everything. The one thing I dont like about it is the sensor wires are extra long.
Old 03-03-2017, 12:05 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Give John Spears a call at Speartech and run it by him. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 03-07-2017, 05:55 PM
Old Geezer's Avatar
Last 2 LS3 kits I am aware of, ate the transmissions. 4L70E.
Old 03-07-2017, 08:23 PM
Gen5GTO's Avatar
Ate the transmission WOW
Old 03-08-2017, 01:55 AM
1975delta88's Avatar
The GM Kit doesn't control the transmission. You have to use a separate transmission control unit to control the transmission
Old 03-10-2017, 10:33 PM
KW Baraka's Avatar
I have the Speartech wire harness and controller made to my specs on my '95 Impala with the 4L60E trans and have had NO PROBLEMS with it at all.
I can't speak to the quality or usefulness of the GM part.
KW
Old 03-11-2017, 11:59 AM
Jimbo1367's Avatar
SPeartech gets my vote.
Old 04-20-2017, 08:16 PM
kwhizz's Avatar
x 2.....................
Old 05-30-2017, 09:15 AM
brandon6.0's Avatar
ive ran speartech and psi on 2 diff swaps. the speartech harness is way nicer. comes fully wired compared to a psi. We used a speartech harness on my buddies gen5 c10 swap with the factory 6l80e without issues. very nice harness for the money!
Quick Reply: Controller kits GM vs Speartech
