2017 LT1 wiring harness
I have a 2017 LT1 engine without any wiring harness, ECM ,pedal , Fuel sensor ,vss, etc. I can purchase the engine harness $305, ECM $200, pedal $100, but I don't know if they will be the correct parts, and then having to modify the harness , reprogramming the ECM and hooking everything up.
A lot cheaper than buying a stand alone kit .
Any help, wiring diagrams , tips on procedure, would be of great assistance. I know some of you have completed this process, so please help . I can follow instructions and directions.
Fuel injection is a weak point in my skills.
Thanks in advance,
Ed
Thanks in advance,
Ed
Thanks in advance,
Ed
Thanks in advance,
Ed
What transmission are you planning on using?
Instead of doing everything you described above, you can get a Holley Terminator X Max V2 system and have all the benefits that come with it.
https://www.holley.com/products/fuel...njection_kits/
Andrew
Andrew
Thanks for replying.
I have an older Tremec 5 speed that I got about 8 years ago. I think what I am going to do is contact PSI Conversions and have them make up a harness for about $1500.
Whenever I look at Holley parts, they are usually fairly high priced . They can get away with it because they are almost the only game in town.
Andrew
Lakewood also has a bellhousing for LT engines that will allow you to use your older Tremec... presumably it's a T3550 or a TKO?
Andrew
It's a TKO 600 with.64 5th gear. I already found a flywheel for the engine that fits the '621' bellhousing and will use a hydraulic slave cylinder. The car is already hydraulic clutch due to being RHD.
I'll do a little more research into the Holley set-up before making up my mind.
Thanks
Thanks
LS1Tech Sponsor
Give us a call, im sure we can help you out. Terminator has it place if you need nitrous control and stuff like that. But ALL it tunes for you is the air/fuel to what you tell it to do. Most of us don't want to be full time tuners.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
The following users liked this post:
righthanddrive (04-03-2021)
Kudos to Tony and the rest of the team for making harnesses for LS and LT swaps. I just ordered mine, and should be here in a couple of weeks. I am glad they are a sponsor of this website.
G Atsma (04-02-2021)
