Generation V External Engine LT1 Bolt-Ons | Intakes | Exhaust | Ignition | Accessories
L83 to 4l80e flex plate
Old Apr 26, 2022 | 01:58 PM
dill30705's Avatar
Default L83 to 4l80e flex plate
Having a hard time finding any info on what it takes to mate 4l80e to Gen V 5.3 l83.
Any info or pointers would be great. I seen one mention of tci flex plat with a custom bushing but I couldn’t figure out if it was custom torque converter or factory style 80e converter.
thanks for any pointers in right direction hopeing to keep this budget minded so any budget friendly options would be great. Also my 80e is a 01 from express van.
Old Apr 26, 2022 | 02:09 PM
theunderlord's Avatar
Gen V crank flanges are 8 bolt, GM makes one, P/N 19125597, it's made for the LSA which also uses the 8 bolt crank and is designed to use with the LSX engines
19125597
8-Bolt Crankshaft Adapter Kit – LSA/LSX454
• Use with LSA, LSX454 and LSX454R crate engines with
8-bolt crankshaft flange
Includes flexplate, adapter hub and hardware
• Provides the correct converter pilot support for production
4L80/85 style torque converters
• Conventional 6-bolt flexplates do not bolt up to LSA and
LSX454 engine
Old Apr 26, 2022 | 11:11 PM
dill30705's Avatar
Awesome that’s what I found but wasn’t sure it was correct. I couldn’t find how many tooth flywheel l83 used for sure to know if it was correct. Do you know what starter is the correct one for this combo? My block doesn’t have one with it so want to make sure I know with LS there was a large and small starter wasn’t sure if LT gen V is the same way or not I’m new to them completely.
Old Apr 26, 2022 | 11:22 PM
The starter that GM recommends for that specific flywheel (it's also listed in the GMPP catalogue too) on the LSX is the 2009 LS3 Corvette starter, page 119 on the GMPP catalogue.
However, the starter that I had looked up for a LT4 build was #12619241, so, maybe google around and see what you can find there.
Check out SwapTime on YouTube too, Mitch has a ton of GenV stuff up and he might be of help too.
Edited to add; I will say that GM / AC Delco Starters are one of the most confounding things I've come across when learning about LS/LT. There are like 4 billion variations, sizes, outdated threads, and superseded part numbers, and it's absolutely not easy. take lots of notes and keep your receipts is my only advice.
Old May 5, 2022 | 08:12 PM
dill30705's Avatar
Default Think I found a working combination.
Order the GM performance flexplate and torque converter adapter ring kit (19125597) and got a jegs hitachi LS mini starter. won’t know for sure til engine is in and really try it but looks like everything meshes perfectly and will happily work together.
Next step is bolt up the trans and test once trucks they are going in a are ready. Sadly that is months away from happening.
Old May 6, 2022 | 12:27 AM
Hell yeah man, be sure and post back what worked for you. Gen V swaps are depending on you!
Old Jun 28, 2022 | 10:16 AM
dill30705's Avatar
Default It worked!
Bolted trans and motor together and spun it over last night with starter. Everything went together perfect. 5 bolts lined up for bell housing to engine block. Flexplate and stock torque converter with hitachi style jegs LS mini starter all worked together perfect.
For reference I’m also using speed engineering shorty LT headers and dirty dingo slider c10/small block Chevy engine adapter mounts with Holley LT swap oil pan and I have tons of room around engine and crossmember. So far so good!
wish me luck on cam install and DOD lifter delete as that’s the next step.
Old Jun 28, 2022 | 12:01 PM
Awesome man!
Old Jun 28, 2022 | 03:03 PM
Ls7colorado's Avatar
Its so shiny, did that come out of a boat or something?
Old Aug 25, 2022 | 10:15 AM
ryeguy2006a's Avatar
This is great info! What ECU are you running to control them both?
Old May 6, 2023 | 10:01 AM
dill30705's Avatar
Yes came out of a 2019 Malibu. Had dod lifter failure at 25hrs and was warranty replaced. I did DOD delete, BTR stage 2 truck cam and arp head bolts.
dill30705's Avatar
holley terminator xmax
Old May 6, 2023 | 10:03 AM
dill30705's Avatar
Current status of project. Coming along nicely.
Old Jan 8, 2026 | 10:22 PM
dill30705's Avatar
Default Truck 99% completed for a year or so.
Incase anyone find this for future the truck runs and drives great. Terminator ecu controls engine and trans beautifully together. No issues whatsoever with engine or trans. Never got tune fully sorted before used trans bit the dust but figured while trans is out I should rebuilt it and change converter to one with a small stall and thrown in a turbo because why not 🤷🏻‍♂️.
Quick air to water setup because no air to air intercooler room and should be firing it back up soon.
Fingers crossed my trans rebuild goes well. First 4l80e but shouldn’t be hard compared to 10r80 ford just got done doing for the wife’s navigator.
Yes the truck is still missing some trim maybe one day I’ll get around to finishing that part 😃.
