Oil pan gasket
The gray crap in a tube, when used correctly in the right application, works better than cork/paper gaskets.
It is a polymeric seal between 2 stationary metal surfaces, sealing flexibly where paper does not.
The following users liked this post:
SAPPER (08-25-2022)
G Atsma (08-25-2022)
Directions say to apply the gray stuff, let it sit for a few minutes and then torque it. If you have a little more bead than required, it hangs over the inside of the oil pan. That's all I need is for a piece of this to break off and get in the oil system. In other words---it's Crap!
Nobody would use this gray stuff if there was a gasket available.
G Atsma (08-26-2022)
Thanks!! Never seen one of those before.
I did go to the GM dealer a while before I posted this and got a short tube of that gray seal. Put it in my gun, cut off the end, poked a hole in the seal and I could barely squeeze the trigger. I guess it had been at the dealer a long time---expired in August. 20 bucks down the drain. I did try a tube from the parts store. It came out a lot easier but I didn't like the final result---put the pan on anyway and let it sit for a week. Wayyy too easy to take off. It would have leaked. I cleaned the rails with acetone and alcohol, so I know they were squeaky clean. I ordered a 2012/ 5.3 oil pan gasket today. I want to see how close it fits. If it doesn't, I think I will pay a machine shop to put a groove around the pan and order some round silicone and use that. That's how much I hate this goop stuff. The back crank cover has to be fixed also. My deal is---I don't want to build this engine, put it in the car, bolt up the trans, hook up the wiring and find out it has a leak and have to pull it out. My brain can't understand why GM would use a nice gasket up until 2013 and then start with the squeeze tube. Cheap bastards
I thought a gen 4 oilpan gasket might be made to work on the gen V. No way. The back 4 holes line up, but that's all. Plus the Holley oilpan has such a narrow rail the silicone part hangs off to the inside.
SAPPER (09-04-2022)
The black is good too. I just prefer the gray.
The best thing to do is become good friends with a tech that works at the dealer. They will have more GMS, Dexcool, and Dex VI stuffed in a box or locker than you can imagine. He can hook you up with as much misc stuff than you'll ever need.
