Generation V Internal Engine 2013-20xx LT1
Lt1 vs lt4 internal
Old Jun 14, 2017 | 10:17 PM
goohead's Avatar
Default Lt1 vs lt4 internal
So I been reading over the lt1 and lt4 specs and it seems aside from the compression difference of the domed vs dished pistons the internals seems pretty much the same?
Does anyone know if there are any other differences? Oil squirted, oil and coolant routing, etc??
Thanks
Old Jun 15, 2017 | 05:26 PM
goohead's Avatar
Anyone? Or should I post in a different section?
Old Jun 15, 2017 | 10:01 PM
You are in the right section. Give it a little more time.
Old Jun 16, 2017 | 08:53 PM
big hammer's Avatar
Lt4 has stronger components all around
Old Jun 18, 2017 | 12:37 AM
goohead's Avatar
Thank,
Any specific parts that are stronger on the bottom end?
I'm assuming block casting is the same, and the crank from what I can is the same as well.
Any specifics would help
Old Jun 18, 2017 | 03:19 PM
Jimbo1367's Avatar
Try going on www.paceperformance.com and checking the spec's of each engine. I'd bet there is more info there.
Old Jun 20, 2017 | 12:12 PM
Reckless's Avatar
Super Moderator
This is a helpful article. Google is your friend
http://media.chevrolet.com/media/us/...owerhouse.html
Old Jun 21, 2017 | 09:09 AM
KW Baraka's Avatar
Originally Posted by Reckless
.........Google is your friend .........
Indeed
KW
Old Jun 27, 2017 | 09:57 AM
DRBC43AMG's Avatar
^1 excellent article
Old Nov 2, 2017 | 01:20 PM
nobreaks254's Avatar
Anyone know the wrist pin size?
