What's going on with this motor?
any idea of what could cause this??
As for the work done to the truck, ls7 (gm performance) lifters, new trays, new brian tooley springs and seals. Texas speed cam, new ngk spark plugs, lingenfelter dod plugs and vvt lock out. Also long tubed headers installed.
truck was also tuned, there are zero codes (CEL), The fuel trim for that side are higher, however the tuner doesn't seem concerned after asking him about it. I did a comparison test of cyl. 5 with results around 210
These are arranged how they came off the heads,
I'd be willing to wager that yes, the engine was running hotter than normal, but you didn't realize it because of the factory gauge strategy.
Factory gauges on these trucks ARE NOT ACCURATE. They go to the middle of the gauge (215 degrees) once they get to about 180-190 degrees, then stay there until about 225-230. I've watched this on a scanner.
Your gauge was probably reading the same level, even though the engine AS A WHOLE - at the thermostat outlet - was probably running about 15-20 degrees hotter.
But that one bank was getting a lot hotter, and it was hotter towards the rear, which is exactly what would happen if the gasket was flipped.
If both gaskets were flipped, you'd have overheating issues pretty quickly.
If this is the case, I'd be really suspicious of the cylinder head/ block surfaces.
