Generation V Internal Engine 2013-20xx LT1
feedback on build before i pull the trigger.
Old Nov 21, 2023 | 02:40 PM
Xlexustech's Avatar
Default feedback on build before i pull the trigger.
Starting pint 2017 GMC sierra 50K miles, headers and exhaust + Magnason tvs 2650 8lbs boost
Picked up a 5.3 with 105K on it.
Plans.
5.3 std bore, H beam rods and new pistons from GPI
TSP stage 1 supercharger cam Lifters springs
Factory 214 casting heads with CNC porting by GPI
Head and msin studs
Stock Crank.
Billet stall converter.
Goal 700 wheel good daily driver. under 20lbs boost.
Am I crazy or is this reasonable
Old Nov 21, 2023 | 03:04 PM
214 casting???
Old Nov 21, 2023 | 03:21 PM
Originally Posted by G Atsma
214 casting???
It’s a Gen5 cylinder head. Direct injection stuff.
Old Nov 21, 2023 | 04:58 PM
Xlexustech's Avatar
Correct Gen V ..
Old Nov 22, 2023 | 10:05 AM
Plans.
5.3 std bore, H beam rods and new pistons from texas speed.
Head and msin studs
Stock Crank.
Billet stock stall converter.
You mentioned 8 lbs of boost up top, and under 20 lbs at the bottom. I think this is doable as long as your willing to turn the boost up some. Doubt you’ll get to 700 wheel at 8 lbs…might take 12-15+. The Gen5 stuff is crazy efficient.
Old Nov 22, 2023 | 11:39 AM
Kjduvall's Avatar
gpi makes some really nice gen5 cams too, and get the larger fuel lobe. also more stall (you didnt say size but.....)
Old Nov 22, 2023 | 12:09 PM
Xlexustech's Avatar
Sorry let me clarify, I am running 8 pounds now with a bone stock motor.
I was thinking of a 20 lb max after the rebuild with a new upper pully and a boost controller.
Old Nov 22, 2023 | 12:14 PM
Xlexustech's Avatar
Originally Posted by Kjduvall
gpi makes some really nice gen5 cams too, and get the larger fuel lobe. also more stall (you didn't say size but.....)
I am picking up all my other stuff from them (rods pistons oilpump) and they are doing the porting. they have a turbo cam and a low lift cam and High lift cam for the l83 but no supercharged cam per se.
BTR on the other hand has a superchanrger cam
Old Nov 22, 2023 | 01:31 PM
Ok gotcha. You should have no problem at all hitting 700 wheel.
