Group Purchase Requests Please post your GP requests here for the sponsors to consider them.
Strange 12-bolt
Old May 3, 2006 | 11:43 PM
Venkman's Avatar
Default Strange 12-bolt
Who would be up for a strange 12 bolt GP?
Old May 11, 2006 | 12:40 PM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
What kind of price range do 12bolt gp's run now with all these "exotic" rear choices these days?
Old May 11, 2006 | 01:28 PM
tbyrne's Avatar
We can do something for 3 or more orders. They usually sell for $2469.99. A GP would save you a few hundred $..
Old May 14, 2006 | 05:59 PM
bad6as's Avatar
interested
Old May 14, 2006 | 09:13 PM
monsterls1's Avatar
I would be interested, what's the price?
Old May 15, 2006 | 11:39 AM
tbyrne's Avatar
We can do this for $2174.99.
The rears are shipped freight collect so we don't get the shipping quotes from them. Most that I've heard of usually cost between $125. and $250. to ship.
Old May 15, 2006 | 04:10 PM
bad6as's Avatar
what are the options with a strange 12b
Old May 16, 2006 | 08:19 AM
tbyrne's Avatar
Options are -
R5206 Upgrade to aluminum support cover $114.99
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings. $229.99
gmbbpcore Options: If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles. The backing plates are only required for 1998+ cars.. $229.99
Old May 16, 2006 | 06:51 PM
bad6as's Avatar
what diff?
Old May 17, 2006 | 12:39 AM
Chris81's Avatar
I'm interested!!!
What spline axle, differental.. etc for that price?
Old May 17, 2006 | 12:06 PM
tbyrne's Avatar
Here is the rundown -
Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10.
Old May 17, 2006 | 07:06 PM
bad6as's Avatar
is there any other posi units available?
and could a T/a style cover be used?
does the drive shaft need to be shortened?
Old May 27, 2006 | 01:33 AM
94z28L's Avatar
man thats a good price on one of these, and for all the options you can get with one its gotta be hard to pass up if you need one
Old May 28, 2006 | 04:57 PM
bad6as's Avatar
up date?
Old May 29, 2006 | 01:26 PM
98FiveSeven's Avatar
i ma interested but it may be a minute. unless i talk to the bank again..
Old May 30, 2006 | 02:53 PM
tbyrne's Avatar
There hasn't been much interest in this in the last few weeks so I don't think it will go anywhere. The shaft won't need to be shortened and a support cover is available.
Old May 31, 2006 | 07:39 PM
bad6as's Avatar
if i order one would i be able to get that gp price?
Old Jun 1, 2006 | 08:13 AM
tbyrne's Avatar
We need two other orders to make that happen.
Old Jun 1, 2006 | 06:44 PM
bad6as's Avatar
come on guys
Old Jun 5, 2006 | 03:17 AM
94z28L's Avatar
theres guys on here puttin down serious power, some of you guys gotta need it
