hello from Cleveland Oh
Old Jan 11, 2015 | 03:36 PM
Eckel974's Avatar
Default hello from Cleveland Oh
Im new to the site. I have a 1971 camaro with sbc 400. I just picked up 2000 lq4 with harness and computer. I am hoping to swap. any advice is apreciated. my car has stock hood so I know I will need intake, fuel rails, and either f body drive acc. or make some brackets. I was trying to figure out how to post a thread to buy that stuff here but Im not sure where or how. thanks for the help!
Old Jan 11, 2015 | 07:40 PM
76larkman's Avatar
welcome to site. I think you can run truck intake and still clear hood. LT1Swap.com has info on the wiring. I have a 5.3 in my 76 skylark it fits under hood. look on craigs list in your area, ebay or look into parts section on here. I believe hooker and holley has swap mounts that will work well for you. you will need a oil pan, don't use the GM muscle car pan as it hangs lower than crossmember. I know as I need to change mine from experiencing it before I read on here about it. good luck.
Old Jan 11, 2015 | 08:05 PM
camarochvy21's Avatar
Welcome
Old Jan 11, 2015 | 08:34 PM
Eckel974's Avatar
thanks for your input. from what I read is the truck intake is about 1 in to high on second gen camaro with stock hood. I have not been able to find anyone who has been able to make it fit. Does anyone know if the truck injectors will work with car intake.
Old Jan 11, 2015 | 08:36 PM
Eckel974's Avatar
What oil pan do you Plan on getting?
Old Jan 11, 2015 | 08:37 PM
Eckel974's Avatar
Default H
I heard the hummer pans work. I take the back I guess the hummer pan is the same has the muscle
Last edited by Eckel974; Jan 16, 2015 at 08:25 AM. Reason: Hummer pan is the same as muscle
Old Jan 11, 2015 | 09:20 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
welcome,Euclid Ohio here.
Old Jan 13, 2015 | 07:27 AM
joyridin''s Avatar
Hey Guys..I'm from Parma. Just trying to get some info for my swap also. Way too much info, not enough time!
Old Jan 15, 2015 | 04:55 PM
Eckel974's Avatar
Default s
whats the swap going in? fuel injected or carbed?
Old Jan 15, 2015 | 06:26 PM
BOBS99SS's Avatar
Captain Double Post
I'm not sure what you need but I have a few ls1 intakes,stock rails, stok injectors,44lb injectors, and a few other things,if there is anything else ya need I'm sure I can find it, I'm right outside of cleveland 440 935 6738
Old Jan 16, 2015 | 08:28 AM
Eckel974's Avatar
Default J
Pm sent!
Old Jan 16, 2015 | 11:02 AM
216StealthSS's Avatar
Welcome, cleveland ohio here also.. hope to see you around in the spring/summer!
Old Jan 17, 2015 | 10:52 PM
Eckel974's Avatar
I'm looking for f body oil pan and front drive accessories
