Proper terms for LS engines
Old Nov 10, 2007 | 03:16 PM
speedydeedy's Avatar
Default Proper terms for LS engines
Hello everybody.I am from SE LA.I have been into hot rodding SBC for many years,now I would like to learn proper tech on LS engines.I am building a 1931 ford model A 5 window coupe semi pro street. I have a 2003 5.3,what is the proper name and the differance between LS,LS1,LS2,etc?
Old Nov 10, 2007 | 04:57 PM
fenix999's Avatar
LQ4/LQ9 5.3/6.0 truck iron motor (Various piston and heads combinations were the difference between all of them)
LS1 Aluminum 5.7 (1998-2004? Corvettes and Fbody's)
LS2 Aluminum 6.0 (GTO, C6 corvette, Trailblazer SS etc)
LS3 Aluminum 6.2 (aka L92 in the new escalades/yukon's)
LS4 impala/monte carlo's
LS6 Aluminum 5.7 (different cam heads etc)
LS7 Aluminum 7.0 427
Im sure im missing some and a few details but this is the majority of the info you need pretty much. Im sure someone with more info will come in and explain whatever it is you are looking for alot better. Hope this helped some... later
Old Nov 10, 2007 | 04:58 PM
Sharpe's Avatar
If you just want to heap them all together, just call them "LS series engines" or "LSx engines." Also correct would be a "Gen 3 small block," though few will know what you're talking about there.
Take a look at the FAQ in this section. Here's a couple good ones from it:
https://ls1tech.com/forums/showpost....8&postcount=10
https://ls1tech.com/forums/showpost....82&postcount=4
Old Nov 10, 2007 | 06:57 PM
Thanks alot this will get me started.
Old Nov 10, 2007 | 07:04 PM
Smile
Thanks alot.As I said I have been at this awhile so I do know gen I,II,III.I never heard of LSx,what does this generaly refer to? My 5.3 is from a suburban 2003. Is this good for a mild build being my car will be about 2500lbs?
Old Nov 10, 2007 | 07:09 PM
Thewizard15's Avatar
LSx is Just a general term for LS series (gen 3 SBC)
where
x=insert number (1, 2, 3, 4, 6, 7)
Old Nov 10, 2007 | 07:47 PM
87gnx's Avatar
Alot of us use the general term "LSX" that pretty much covers them all.$.02
Old Nov 11, 2007 | 12:46 PM
Smile Just learning
Thanks to everyone for your help.Can someone tell me the stock hp and tourque on my 2003 1/2 ton suburban 5.3?
Old Nov 12, 2007 | 01:46 PM
bene's Avatar
Trunion King
5,328 cc 5.3 liters 8 V front engine with 96 mm bore, 92 mm stroke, 9.5 compression ratio, overhead valve and two valves per cylinder L59
- Unleaded fuel
- Fuel economy EPA highway (l/100km): 13.8
- Multi-point injection fuel system
- Main 117 liter unleaded fuel tank
- Power: SAE and 213 kW , 285 HP @ 5,200 rpm; 325 ft lb , 441 Nm @ 4,000 rpm
