Replacing front brakes...
Link to a do it yourself article from an older GP
Not exact instructions but close enough.
also, but sure to open your bleeder valve while you compress the caliper pistons.
http://www.2carpros.com/how_to/how_t...ace_brakes.htm
i used that one and it worked out very well for me.
http://www.clubgp.com/newforum/tm.asp?m=4556195
I left the rotor alone as I didn't think turning was necessary and wasn't going look for someone that can turn drilled rotors so no torx needed. Also the bolts for caliper to bracket, and bracket to car are not torx like older cars. I didn't bleed some fluid, maybe I should have but I thought the car was new enough and there wouldn't be much fluid travel upstream. So far everything is great and no dust!!
