another exhaust question
Old Jun 25, 2009 | 12:29 AM
TheMonteMan's Avatar
Default another exhaust question
Ok so i already have the magnaflow cat back on the car and its just not loud enough for me. and no i dont want to invest in a cut-out. im going to keep the magnaflow res and remove the mufflers and buy 90* bent stainless tubing my question is how do i go about using the factory hanging point? the hangers are welded to the mufflers. i know there was one guy on here that did it just dont know how. any suggestions?
Old Jun 25, 2009 | 01:01 AM
Panther427's Avatar
Well a muffler shop has pre- bent hangers that they just weld on once they get everything lined up
Old Jun 25, 2009 | 02:35 AM
williamGT's Avatar
My magnaflow cat-back is loud, because of my 3inch hogan downpipe with cat.
When I just had only the magnaflow cat back for a mod, it was too quite, i was like thats it...
Old Jun 25, 2009 | 08:36 AM
MCSS07's Avatar
The Magnaflow cat/back sucks IMHO.
Take everything off but the Magnaflow res, and then get an exhaust shop to make a custom pipe going all the way back and split into 2. Put some nice tips on the end and enjoy your new exhaust.
The Magnaflow with 409SS will get surface rust where 304SS will not and looks alot better.
Also, the downpipe doesnt really make that much difference since our stock pipe is not that restrictive from factory. I had the hogan DP7 and after 500 miles, I sold it because of the lack of exhaust sounds.
Old Jun 25, 2009 | 12:47 PM
Bryan921SS's Avatar
20SS07 that is what i was thinking of doing...do you have any sound clips of your exhaust set up?
Old Jun 25, 2009 | 02:17 PM
Mgpeagle's Avatar
I had a factory downpipe and it measured 2 1/4" in dia. The Hogan is mandrel bent and a full 3" in dia. I noticed a HUGE improvement in performance; especially up top. I hate to be the bearer of bad news but the factory DP is a pipe within a pipe. This was done at the factory to reduce engine noise. The outside may look large but the inside is very small for a V-8. The V-6's are the same exact way. A new larger dia. DP will wake the car up especially in the upper RPM's. Well, every car is different.
-Mike
Old Jun 25, 2009 | 02:53 PM
06 SS's Avatar
I would ditch the resonator first, should perk up the mufflers considerably.
Old Jun 25, 2009 | 10:19 PM
MCSS07's Avatar
Nope, do the opt of that.
I was running the magnaflow system with a straight pipe in place of the res and it made no differences. I then put the res back on and removed the mufflers and got the sound I really wanted.
Old Jun 25, 2009 | 11:54 PM
williamGT's Avatar
If you remove the res it will make that poping ras noise.
Old Jun 26, 2009 | 06:32 PM
MCSS07 do you have any shots of your exhaust? im not getting rid of the magnaflow pipes theyve already been paid for. you are correct they do look like *** but im not that all concerned about how they look. just intend on removing the mufflers and running straight pipes. just curious how you guys that did this ran your hangers.
Old Jun 26, 2009 | 10:08 PM
MCSS07's Avatar
I dont have my cam with me right now, but in the next few weeks I will.
I went through about 1200.00 in exhaust parts including the magnaflow system, Hogan down pipe and res. straight pipe from hogan before I got sick of everything and took it all off, started with just the res and got the exhaust custom made from there.
The main problem I found with the magnaflow is that it will rub on your rear sway bar if you do not check it often.
As for the hangers I believe the tech just welded a few on each side of the straight pipes while he was welding on my tips.
Old Jun 26, 2009 | 10:29 PM
i figured as much. i plan on doing it at home and have a muffler shop weld the hangers on for me.
Old Jun 27, 2009 | 08:58 PM
beznich's Avatar
I have the catless downpipe and the Magnaflows, and love it. The Flowmasters were too loud without the CAT, and I do alot of highway driving.
Old Jun 28, 2009 | 02:36 AM
i dont mind loud i run my 80 with headers straight back to flowmaster 40s no cats and that was my daily driver for 8 years. loud is good as long as you can back it up. the magnaflows just not loud enough.
