Thorley Header Project Update
Old Mar 24, 2010 | 06:51 PM
  #901
DavidGXP's Avatar
You "all" worry way to much just put the headers on all ready! They are warranted! Mine will be going in this weekend and I don't think the install will be all that hard. The instructions even give us a tool list! I'm going to use a exhaust clamp at the collector and have a shop weld up the cat and if that don't work then I'll install a flex pipe and have an exhaust shop install my cat.
Old Mar 24, 2010 | 06:53 PM
  #902
DavidGXP's Avatar
I have a Hogan 3" down pipe and am wondering if the collector will fit over the Hogan pipe? I also wonder if the my cat is at the right angle since I had a exhaust shop weld in a 3" cat outlet. Now I'm worrying!!!! During the header install might be a good time to install so E3 plugs there probably a wast of money but I'll give them a shot.
Old Mar 24, 2010 | 07:00 PM
  #903
williamGT's Avatar
I'm getting mine installed next week now (wednesday, thursday or friday) is the Flex pipe needed though? will the engine flex alot?
Old Mar 24, 2010 | 07:04 PM
  #904
Mels SS's Avatar
There be headers here
Old Mar 24, 2010 | 07:08 PM
  #905
Mels SS's Avatar
If you have the dogbone I have the motor doesn't move at all
http://www.3800performance.com/Merch...roduct_Count=4
Old Mar 24, 2010 | 07:35 PM
  #906
ImpSS07's Avatar
I got mine in today!!! Damn mailman just left them on the doorstep of my "shady" apartments, *******!!!
Old Mar 24, 2010 | 07:36 PM
  #907
williamGT's Avatar
I don't think the flex pipe will work, no room.
Old Mar 24, 2010 | 07:44 PM
  #908
07carlocrusader's Avatar
ohh!!! Now I see what ya mean William!! I don't know, good question! Hopefully not!
Congrads Mel!! And maybe I'll order those dogbones(well dogbone) to ensure no flex issues!
Old Mar 24, 2010 | 07:55 PM
  #909
williamGT's Avatar
Ya, I'm going to order 1 dogbone tomorrow.
Old Mar 24, 2010 | 08:09 PM
  #910
williamGT's Avatar
Did you get the round msp poly mounts?
Old Mar 24, 2010 | 08:40 PM
  #911
TiredGXP's Avatar
I'd prefer to put a flex in the downpipe. Poly dogbone sounds like a good idea too.
Oh, headers came today.
Old Mar 24, 2010 | 08:56 PM
  #912
Mels SS's Avatar
Yes sir and this
http://www.3800performance.com/Merch...ct_Code=MSP-MM
Old Mar 24, 2010 | 08:58 PM
  #913
Mels SS's Avatar
So what exactly needs welding? and where I have the stock down pipe and cat Please explain.
Old Mar 24, 2010 | 09:16 PM
  #914
BuickRacer's Avatar
The secondary collector (see photo at the bottom of page 45) gets welded to the downpipe...which you have to cut.
Old Mar 24, 2010 | 09:39 PM
  #915
mixerda's Avatar
just run it open, you and your neighbors will get used to it after a while
consider it a weight saver since you won't be needing the rest of the exhaust hahaha
Old Mar 24, 2010 | 10:10 PM
  #916
AlabamaGuy's Avatar
I'm probably going to have mine flanged. I did buy a 6" piece of 3" flex pipe, though.
Good thing I've got a good group of friends to help me put it on. Just have to feed them!
Old Mar 24, 2010 | 10:21 PM
  #917
The only spot is here:
Everything else is bolt on!! If you want to do most of the work and you have patience, do it!! And bring it to a nearby shop and get that part welded! Mel, you actually going to cut pretty much ALL your downpipe!! All the way to about a 1/2 right before the cat!! Why? Cause if you notice on your/our rear headers, they begin to slope downward and keeps going with the collector until the "welding" area. So this eliminates a necessity down pipe.......
Or you can just leave it open, like mixerda says!! Haha!!
Old Mar 24, 2010 | 11:19 PM
  #918
neilownz's Avatar
It would probably be cheaper to do most of it, tow the car to the shop, and have them finish it. Hell if it's not super loud I would drive it there and just keep the rpms low.
Old Mar 24, 2010 | 11:33 PM
  #919
AlabamaGuy's Avatar
It'd probably be a little bit louder than a open catless DP.
Old Mar 25, 2010 | 12:43 AM
  #920
Thats exactly what I'm going to do!!
