Thorley Header Project Update
Old Mar 28, 2010 | 11:54 AM
  #1001
Mels SS's Avatar
Originally Posted by Haulin_Ls4_GxP
I'm going to call Monday and see what we can get going on getting a F.A.S.T. Manifold getting made.
I sure would be in for that!!
Old Mar 28, 2010 | 01:11 PM
  #1002
DavidGXP's Avatar
Originally Posted by monte_with_a_LS4
you still need to add it into your signature
You got that right!
Old Mar 28, 2010 | 01:16 PM
  #1003
DavidGXP's Avatar
Originally Posted by BeckZ06
The hogan dp fits these headers right?
Yes, but you will need to cut it and use a 3" i.d piece of pipe to slip over the cat inlet and collector. If your going to use a clamp then make sure you leave enough material on the inlet to clamp onto. you can get the piece of pipe from parts store unless you wand stainless steel, which I recommend.
Old Mar 28, 2010 | 04:28 PM
  #1004
Mels SS's Avatar
So David do you think the clamp would work this type from Magnaflow from the down pipe to the cat
also what size of band clamp
Old Mar 28, 2010 | 04:40 PM
  #1005
neilownz's Avatar
Smear some of that permatex or similar exhaust sealant around it before clamping to make sure it doesn't leak.
http://www.permatex.com/products/Aut...ipe_Sealer.htm
Old Mar 28, 2010 | 04:46 PM
  #1006
AlabamaGuy's Avatar
I believe anything more than a ported LS6 would flow WAY too much for our engines.
Old Mar 28, 2010 | 05:20 PM
  #1007
higsy's Avatar
Haha. Can't you let my bank account recover first before ya do it. lol. I still want to get an inferno and TEP tranny later this year!!!
Old Mar 28, 2010 | 05:26 PM
  #1008
DavidGXP's Avatar
Thats the clamp that I'm considering using I've gotta call Summit later on tonight.
For me 3" id to 3" od
Old Mar 28, 2010 | 05:51 PM
  #1009
Haulin_Ls4_GxP's Avatar
I disagree with that. If u get a bigger cam and some nice heads I think it would work very well. Guys put them on the 5.3 truck engines. I'm sure you might lose some bottom end but would gain a lot of top end. I would rather have a little more top end over bottom.
Old Mar 28, 2010 | 06:17 PM
  #1010
DieselPump's Avatar
I'd be in for this too!
Old Mar 28, 2010 | 06:24 PM
  #1011
DavidGXP's Avatar
We dont have the gearing for more top end power so we need to focus on low to mid range power. Especially with a 4spd (2spd considering 2nd shifts into 3rd around 98-100mph!)
Old Mar 28, 2010 | 07:30 PM
  #1012
ji22my's Avatar
Best I have.
http://www.youtube.com/watch?v=ya5-vN8c-Qc
Old Mar 28, 2010 | 07:37 PM
  #1013
Mels SS's Avatar
Is that with your exhaust hocked up
Old Mar 28, 2010 | 07:48 PM
  #1014
ji22my's Avatar
No. that is at the down tube where the cat would go. I had an exhaust shop weld the flange from behind the cat to a straight pipe with an o2 bung. I clamped it in. Now I hear a hissing noise simmilar to a supercharger whine. I cant find any leaks so I assume that the tube has to be welded.
Old Mar 28, 2010 | 08:58 PM
  #1015
ImpSS07's Avatar
Originally Posted by ji22my
I just CAME!!!!!!!!!!
Old Mar 28, 2010 | 11:57 PM
  #1016
AlabamaGuy's Avatar
We have excellent heads already. If you slap a big cam and a FAST on there I feel like the powerband would be moved so far up that the bottom end couldn't handle spinning that high, assuming you want to take full advantage of the powerband. On a larger motor, yes. I feel like ours would benefit more from a LS6 intake and a baby cam.
Old Mar 29, 2010 | 03:36 AM
  #1017
JDMC5's Avatar
I agree that a fast isn't going to be worth much over an LS6 however, a decent size cam is going to be better than the baby cam. You can make the same bottom end as the baby cam but boost the topend greatly.
Old Mar 29, 2010 | 12:08 PM
  #1018
Mgpeagle's Avatar
That can't be going through any mufflers. That is LOUD. Sounds great but I know I'd be pulled over at every stop sign around here. I am putting mine through the stock cat-back with no resonator. For now...
-Mike
Old Mar 30, 2010 | 06:42 PM
  #1019
williamGT's Avatar
Well I'm pissed off, Car is supposed to go in tomorrow to get the headers on, my mechanic wants the car next week now, I took tomorrow off for nothing.
I WANT THEM ON SOOOO BAD!!!!!
Old Mar 30, 2010 | 07:09 PM
  #1020
AlabamaGuy's Avatar
http://www.youtube.com/watch?v=qcS2Ig8clOQ
