Thorley Header Project Update
Old Apr 8, 2010 | 07:44 AM
  #1201
gulfstreamcpt's Avatar
Originally Posted by williamGT
I have the magnaflow cat back and Hogan catted downpipe, but I have the resonator deleted, maybe mine will sound different, my car sounds great without the headers now, but will find out tomorrow when there on.
Hey William,
I also am now thinking of doing the res delete on the cat-back. Since you have basically the same set up, how do you like it? Did you ever run with it on before you took it off? Quite of bit of difference if you did??? Also, is there any/alot of drone in the cabin while cruising down the road??
Just was a bit disappointed with the sound as stated with one of my previous posts, so looking for something to remedy that with.. Hoping this may be the ticket.. Just wanted to know how yours turned out....
Thanx
Old Apr 8, 2010 | 01:42 PM
  #1202
williamGT's Avatar
I had the res on my car for a year with the magnaflow, I took it off last year, the sound was deeper and little ras at revs (sometimes) there is some drone in the cabin (DOD)
as far the whistle noise, I tighten the clamp by the flex, still whistles, I think its the dp weld, louder under the car, taking my car to the shop next week and getting the mechanic to check, I'll be in the car and reving it on the hoist.
Old Apr 8, 2010 | 07:13 PM
  #1203
williamGT's Avatar
I'm taking my car to GM instead next friday, The GM foreman said bring it by, and I asked him will the headers void my warranty if anything breaks, and he said no.
Old Apr 8, 2010 | 09:12 PM
  #1204
Mels SS's Avatar
Mel, I think the smell is normal, mine has the same smell when I installed the MF catback.
The smell is decreasing I looked closer at the weld with a mirror on top there is a spot on top that they missed I am take the car back this Saturday to fix it.
Old Apr 9, 2010 | 03:08 PM
  #1205
Mgpeagle's Avatar
That's what I was thinking. My GTP had a 1/2" of weld missing on top too. I am going to very careful and make sure I get the whole thing. 3 weeks and counting... Feels like forever...
-Mike
Old Apr 9, 2010 | 08:15 PM
  #1206
williamGT's Avatar
I listen to the sound under the hood, but seems louder under the car....so I'm hoping its the weld as well.
Old Apr 9, 2010 | 09:13 PM
  #1207
LS4SPEED's Avatar
Drive more worry less! Thats my new moto. Recheck for leaks after your next oil change. You should be able to see signs of soot, black smokey **** you can easily rub off.
Old Apr 9, 2010 | 09:26 PM
  #1208
Mels SS's Avatar
Agreed I found that the gasket was bad between the res and the cat so I replaced the gasket and used a copper sealant with it all's good now for the weld tomorrow.
Old Apr 10, 2010 | 04:38 AM
  #1209
mixerda's Avatar
In theory I'll have mine on tomorrow or sunday...just the motor won't be inside the car weee....have to replace the flexplate...long story don't wanna go into it... on a good note I'll have some great pics of what it looks like hooked up
Old Apr 10, 2010 | 04:00 PM
  #1210
ohyeahjay's Avatar
Just finished header/shift kit and pretty sure the whistle sound is coming from the flex. Turned the radio up and it went away so I guess it is what it is. shift kit I'd nice as well. It seems to really let the car get into high rpm although first gear is a total waste now.
Old Apr 10, 2010 | 04:07 PM
  #1211
williamGT's Avatar
so you got the whistle too, well my car goes to GM on friday, and also there intalling the headers on the test car (BuickRacer) this week.
Old Apr 10, 2010 | 05:03 PM
  #1212
williamGT's Avatar
Well its a cold day here, so I decided to start the car to see if the smoke comes out of the flex pipe, flex pipe welds on top is leaking, about a size of a good sized nail.... Looks like its cracking more around that area.
I called the mechanic who intstalled it and he said being the car by on Monday and see if it can be welded. I knew that the flex pipe is in a bad spot.
Old Apr 10, 2010 | 06:44 PM
  #1213
ohyeahjay's Avatar
Has anyone tried wrapping the flex to see if helps?
Old Apr 10, 2010 | 06:51 PM
  #1214
williamGT's Avatar
what about that silver muffler tape? just put around the welds.
Old Apr 11, 2010 | 06:15 PM
  #1215
Nick_Nasty's_GXP's Avatar
Is DT still doing these headers for the group buy? I took a look at his website and they were like $960. The $600 or so you guys paid was a steal! I am graduating college in May and I think my parents are giving me a pretty good amount of money, so no better time than now to invest in some headers!!!
Old Apr 11, 2010 | 09:41 PM
  #1216
neilownz's Avatar
No idea. I think williamGT wiped his hands of it so you would need to contact Nick directly.
Old Apr 11, 2010 | 10:12 PM
  #1217
williamGT's Avatar
Yeah you have to contact Nick at Doug thorley headers# 1-800-347-8664
Old Apr 11, 2010 | 11:02 PM
  #1218
JDMC5's Avatar
the flex pipe tick is a common problem, ZZP has a nice piece that will take care of the problem if it bothers you.
Old Apr 11, 2010 | 11:26 PM
  #1219
AlabamaGuy's Avatar
I've developed a nice whistle...I'm trying to determine if it's the headers/exhaust or the belt.
Old Apr 12, 2010 | 09:51 AM
  #1220
williamGT's Avatar
I had the mechanic look at the exhaust, he says the downpipe has to come off and get welded, say couple of hours to do.
