Thorley Header Project Update
Old Apr 6, 2010 | 07:42 PM
  #1161
06 SS's Avatar
Originally Posted by DavidGXP
Crane rockers are the.. **** adds anywhere from 6-8 degrees to the cam and increases the lift.
Not a chance on it acting like a duration increase of 6+*. More like 2-3* max. I would sure like to see the source that claims double that as I could use a good laugh!
Old Apr 6, 2010 | 07:48 PM
  #1162
DavidGXP's Avatar
I'd make a good sales man right?
Old Apr 6, 2010 | 07:53 PM
  #1163
GXP25's Avatar
The only problem I have is, that I'm now done with DOD, and hate the fact that the non DOD lobes have less lift. So, now I wanna cam. Probly go this route http://www.performancetrucks.net/for...d.php?t=438267
Look at his torque curve!
Very impressive!
EDIT:
Thunder Racing Custom Camshaft
"TR 220-112" - 220/220 .551/.551 112 LSA 1500-6500 RPM Power Band. Computer Tuning Required with automatic transmission cars. A very well balanced camshaft that makes excellent power across the entire RPM range. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended.
Old Apr 6, 2010 | 08:03 PM
  #1164
higsy's Avatar
Originally Posted by williamGT
I hope its normal.
Doesn't sound normal to me. Anybody else??
Old Apr 6, 2010 | 08:06 PM
  #1165
Mgpeagle's Avatar
William,
I have no idea what that particular nipple is for. I put a rubber cover over mine about 2 years ago. If someone knows what that nipple is, we'd all like to know.
Damn, when you read this at first....lol...
-Mike
Old Apr 6, 2010 | 08:10 PM
  #1166
gulfstreamcpt's Avatar
I hope its normal.
Don't feel bad William.. I've got the same thing as well. At heavy and WOT is when mine happends.. Like you say, sorta sounds like a whistle... Gotta be a leak of some sort. Not sure if it's at the manifold, the DP/header weld, or something else....
Sounds like a couple of us have the same problem with some searching to do....
Old Apr 6, 2010 | 08:22 PM
  #1167
williamGT's Avatar
maybe flex pipe?
Old Apr 6, 2010 | 08:43 PM
  #1168
maybe flex pipe?
Maybe.... Not sure.... Like I say, gonna take some investigation... Hope this thing isn't gonna be a b*tch to track down....
Old Apr 6, 2010 | 09:35 PM
  #1169
DavidGXP's Avatar
Originally Posted by GXP25
Very impressive!
EDIT:
I'd just ditch my gold race rockers, and run non quick lifts! Can you imagine what that set up would do with our Heads, pp tb, LS6 intake, with roller rockers and our headers! We already have a 3000+ stall and with some 3.29's or 3.69's
Old Apr 6, 2010 | 09:56 PM
  #1170
williamGT's Avatar
I hope not the flex, friends says its the TBS, but when i down shift in TAP shift it whistle's.
Old Apr 6, 2010 | 10:01 PM
  #1171
DavidGXP's Avatar
Mine makes a weired noise when I'm in dod cruising and go to accelerate. I can hear an exhaust fart comming from under the car. POS intake manifold
Old Apr 6, 2010 | 10:06 PM
  #1172
williamGT's Avatar
I'm just pissed, how can we test if its the flex?
Old Apr 6, 2010 | 10:10 PM
  #1173
DavidGXP's Avatar
Put the car up on a rack, running, and listen to every exhaust connection with a stethoscope? Bothers me too, but I love the power!
Old Apr 6, 2010 | 10:20 PM
  #1174
higsy's Avatar
I'm getting concerned now. I don't have a TBS. Was hoping it was a bad weld etc. but with multiple people having the same problem doesn't look good.
Old Apr 6, 2010 | 10:29 PM
  #1175
DavidGXP's Avatar
I wanna a GTO now!
Old Apr 6, 2010 | 10:33 PM
  #1176
higsy's Avatar
Guess my cutout will mask the noise. Damn
Old Apr 6, 2010 | 10:38 PM
  #1177
williamGT's Avatar
well tomorrow I'll take off the TBS and see if it still does that. my friends are car guys and saying '' more air going in more the TBS makes noise''
Old Apr 7, 2010 | 12:53 AM
  #1178
AlabamaGuy's Avatar
My belt is squeaking....I thought it was the headers for the longest time.
Old Apr 7, 2010 | 04:49 AM
  #1179
07carlocrusader's Avatar
asking if he put the TBS to the collector? lol
does this nipple on the throttle body attach to anything? right side says LS4
DP's pic:
William,...this is perfectly normal, its how the gasket is made. IDK why.
When I installed my TB spacer I noticed this is how the gasket is made and the gasket that came with it would had probaly caused a leak! It didn't have that nipple.
Here's mine Will!
Old Apr 7, 2010 | 05:40 AM
  #1180
williamGT's Avatar
Here's mine Will!
hey yout 200-586 is the other way, mine is switched around, maybe they put it back on wrong....thanks
