110 octane without a tune
Old 02-24-2011, 11:19 PM
f3racer's Avatar
Default 110 octane without a tune
Has anyone fill up with 110 oct? There is a 110 pump here that I am thinking about filling up with just for ***** and giggles. Wondering if anyone has a basic review of the difference.
Old 02-24-2011, 11:22 PM
LS1 Racing's Avatar
Well, with a stock tune, you'll have no knock-retard. Hypothetically, the car should be as fast as it will go, however, it could also be that 110 is too much. Meaning, the detonation resistance could be too high for our motors, though I don't know for sure.
I'd like to see 06MonteSS or JDMC5 weigh in on this topic.
Old 02-24-2011, 11:32 PM
CenTexSS's Avatar
Don't think it'd be a good idea.
Old 02-24-2011, 11:39 PM
LS1Tech Sponsor
06MonteSS's Avatar
are you sure that it's UNLEADED??? you do not want to run leaded racing gas - you'll kill your 02 sensors and catalytic converter...
as long as it's unleaded, you'll be fine... your car will run better on it..
I know I have a pump about 20 min. from my house, that is 100 octane unleaded Sunoco GT100... and my car LOVES that stuff... but at $8+ a gallon, I don't use it that often, hahaha...
BUT, you won't be getting the full/true potential from it, since your timing (spark advance) table won't be setup for the higher octane... you could run more timing (up to a point) for that higher octane gas and get even more giddy-up...
but, there comes a point at which, going with too much timing, actually kills your performance... even if you have no KR... just because you can run with a certain amount of timing with no KR, doesn't mean that you're making the most hp/tq with that setting...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 02-24-2011, 11:49 PM
f3racer's Avatar
Its a conoco pump and I am unsure if its unleaded or not. Ill check tomorrow. Its like 650 a gallon and it is 110 octane. So my car will run better with it as long as its unleaded. It will produce a little more power but not much because I'm not tuned to it. Am I tracking correctly?
Old 02-25-2011, 12:04 AM
LS1Tech Sponsor
06MonteSS's Avatar
yes...
__________________
Old 02-25-2011, 12:11 AM
f3racer's Avatar
Thanks
Old 02-25-2011, 12:24 AM
LS1Tech Sponsor
06MonteSS's Avatar
Conoco/Philips is owned by Marc Nelson Oil Products, Inc... and on their site, they state that their 110 octane gas (which is labeled as VP Racing), is LEADED gas...
so make sure you check and find out for sure before putting any of that 110 in your tank!!
usually, from what I'VE seen, anything higher than 104 octane, tends to be leaded...
__________________
Old 02-25-2011, 12:26 AM
f3racer's Avatar
Will do. Thanks again
Old 02-25-2011, 10:10 AM
Sadden's Avatar
I hate working for Conoco-Phillips.
Old 02-25-2011, 01:05 PM
LS1>girlfriend's Avatar
As Lew said, 110 is usually leaded fuel.
Old 02-25-2011, 01:55 PM
JDMC5's Avatar
I agree mostly with what Lew said. I would like to add that sometimes higher octane race fuel has a different stoich ratio than regular pump gas. With stock timing curves Id be surprised to see a gain more than a few hp with the 110, every engine is different though. By nature the higher octane is going to want more advance for max power. All things optimum, I wouldn't expect more than a 10hp gain over premium. Not worth the price tag.
Old 02-25-2011, 01:57 PM
Sadden's Avatar
Agreed.
If he were running boost of some kind though...
Old 02-25-2011, 02:12 PM
LS1Tech Sponsor
06MonteSS's Avatar
yep yep...
yeah, he'll notice a difference, but it's not going to be a whole lot without being tuned specifically for it....
and yeah, the **** is EXPENSIVE...
__________________
Old 03-01-2011, 04:46 PM
chevypro101's Avatar
price difference to performance difference, I don't thinks is worth the extra money for the fuel... put the money on the side for a tune
Old 03-02-2011, 10:08 AM
f3racer's Avatar
tune is coming soon. im not going to use the 110 its only 525 a gallon here but it is leaded fuel so im not using it. thanks for everyones advice.
Old 03-02-2011, 01:58 PM
JDMC5's Avatar
If you want a power gain switch to E85 and get it tuned.
Old 03-02-2011, 10:12 PM
ls4door's Avatar
However the difference between 87 and 91or 92 is a big difference. Or so it seems.
Old 03-03-2011, 02:32 AM
blakss's Avatar
what would we have to do to be able to run E85? just a tune?
Old 03-03-2011, 07:37 AM
f3racer's Avatar
no, entire fuel system needs to be changed.
Quick Reply: 110 octane without a tune
