More power to the wheels
Old Jun 17, 2010 | 12:12 PM
SSCoop's Avatar
Default More power to the wheels
How can i get more power to the wheels with out going turbo? I want headers but i cant afford them until probably tax time. I already have a straight pipe exhaust but i still have my catalyic converter. i also want to be in the mid to high 13's
Old Jun 17, 2010 | 12:25 PM
94ss06gxp's Avatar
i went 13.98 last night and im bone stock with just a cutout (after cat), with a little over half tank of gas, on potenza street tires. so im thinking i get a tune and DP and take my headlight out and im lookin at 13.5-13.8
Old Jun 17, 2010 | 09:45 PM
Tappeter's Avatar
Easiest and cheapest way to make your car faster is not to add power, but to lose weight. It's easy to figure out that if 2 cars make the same power, the lighter one will be quicker. (Never race with a passenger, it'll slow you down) Use your imagination and remove as much weight as you can, your time slips will improve. Also, everyone likes the look of big wheels and tires, but shorter then stock tires will effectively lower your final gear ratio (larger #). For racing, find smaller (lighter) wheels and shorter wide tires.
Old Jun 17, 2010 | 09:58 PM
DavidGXP's Avatar
Synthetic oils. Pump your rear tires to max pressure and lower your front tires to 28-30psi. Race with 1/8 of a tank of gas, and remove all unnecessary weight. (floor mats, CD binder, shoes and crap from your trunk. Pull out your headlight and pop your hood open while sitting in the staging lanes to allow your engine to cool down. Get some computer duster (aerosol can) and spray your maf housing down before closing your hood to cool off your IAT sensor which will reduce timing being pulled from your engine at WOT, from heat soak. Also try to have your lights off and all other electrical equipment off in order to keep the load off of your alt.
Old Jun 17, 2010 | 10:46 PM
CenTexSS's Avatar
I'd start with the basics. Catless downpipe and a tune.
Old Jun 18, 2010 | 01:02 AM
StealthV8's Avatar
I'll second the catless DP, it wakes up 2nd second gear.
Old Jun 18, 2010 | 03:01 AM
Nacho SS's Avatar
+43 For the catless downpipe. 2nd gear isn't as doggy anymore.
Old Jun 18, 2010 | 05:26 AM
DP 08 GXP's Avatar
also might wanna get some spring blockers for the track...helps keep the weight over the front tires
Old Jun 18, 2010 | 12:39 PM
LS1 Racing's Avatar
Just picked up the catless DP. I was gonna try to put it on before tomorrow's cruise, but I don't see it happening.
It's pretty much just 4 bolts, right? I figured I could just run it up on ramps and swap it out.
Old Jun 18, 2010 | 12:59 PM
Nacho SS's Avatar
4 bolts, the 02 sensor (which needs a bung welded in), and the rubber hangers which are a pita.
Old Jun 18, 2010 | 03:12 PM
SSCoop's Avatar
thanks for all your help guys. what about getting a hi flow catalyic converter? im gonna need my cat, right?
Old Jun 18, 2010 | 04:33 PM
monte_with_a_LS4's Avatar
id do the gaskets too
Old Jun 18, 2010 | 04:54 PM
LS1 Racing's Avatar
Thanks!
Seems easy enough, though I'm skipping the rear O2 sensor...Lew will tune it out for me!
Old Jun 18, 2010 | 06:02 PM
CenTexSS's Avatar
Thanks!
Do not use a 12 point 15mm socket for the nuts. Use a 6 point 15mm to get 'em off. I came close to stripping mine with a 12 point. They'd be a bitch to get out if they got stripped.
Old Jun 18, 2010 | 06:45 PM
LS1 Racing's Avatar
Thanks for the heads up...With my luck, I would have stripped it out!
Old Jun 18, 2010 | 10:51 PM
DavidGXP's Avatar
Get some PB blaster and blast away!
Old Jun 18, 2010 | 11:29 PM
JDMC5's Avatar
get a tune they help out a ton
Old Jun 19, 2010 | 03:14 AM
Nacho SS's Avatar
i kinda messed mine up pretty bad until i realized its a 6pt socket.
Old Jun 19, 2010 | 02:00 PM
StealthV8's Avatar
I was lucking when i did mine since i was replace the whole exhaust system. The bolts that connected the dp to the catback were rusted so bad i didn't even bother trying to get them off. I just unbolted the dp from the manifold and then droped the exhaust as one peice and draged the whole system out.
Old Jun 19, 2010 | 02:38 PM
94ss06gxp's Avatar
oh hell yeah!!
