New turbo set up! Group buy
Old Oct 3, 2010 | 10:09 AM
  #121
2005gxp's Avatar
so what all did you add to the origional non i/c kit that we purchaced? When will this upgrade be available? Pricing?
Old Oct 3, 2010 | 10:13 AM
  #122
LS4_DeltaV's Avatar
Just added the Ic portion thats all. It is indeed an upgrade and indeed available now. I will speak with Kevin about the cost of the upgrade and get back to you.
Cheers
Edit: I have the car here just south of Pembroke if you would like to come for a rip >:]
Old Oct 3, 2010 | 06:36 PM
  #123
supercatxr7's Avatar
Good stuff! 500+ should be easy!
Old Oct 3, 2010 | 06:40 PM
  #124
2005gxp's Avatar
would love to go for a rip, im closer to ottawa tho.
Old Oct 3, 2010 | 06:57 PM
  #125
LS4_DeltaV's Avatar
In case anyone is interested, here is a comparision between a stock GXP with a magniflow exhaust and a CAI, the non ic kit, and the ic kit.
Its quite an eye opener.
Cheers
Old Oct 4, 2010 | 05:53 PM
  #126
i_ammetal's Avatar
Cheers
Wow.... thats some serious numbers
IC is the only way to go then...
Any word on gas mileage with the kits?
Old Oct 4, 2010 | 09:03 PM
  #127
LS4_DeltaV's Avatar
Same as stock....till you push on it. Car drives just like a stock car. Same if not a little better than before. In normal driving modes that is.
But if you have a heavy foot and you're into boost all the time, Dont expect it to be wonderful
Cheers
Old Oct 4, 2010 | 09:11 PM
  #128
LS4_DeltaV's Avatar
Yeah we're really gettin our **** together with this package. Next runs will be 94 Octane and 12 Psi. We will expect to see 540 +.
But first, an LSD,
Cheers
Old Oct 5, 2010 | 09:52 PM
  #129
06 SS's Avatar
Don't forget that you are not seeing an improvement due to the intercooler. It is due to the ability to run more boost with one. The non-IC graph appears to out perform the IC graph as would be expected at low boost numbers due to pressure drop across the intercooler and the earlier onset of meth/water injection. A little back of the envelope math tells me that a 5 PSIG increase in pressure is going to add (roughly) between 40F and 50F to intake temps from ambient (between ambient of 10F to 115F) BEFORE the m/w injection which would drop the temps considerably and it was not a huge temp increase to begin with.
You would put more power down to the ground below 4600 RPM or so with the non-IC kit. I don't think you are going to see much difference on the street due to not being able to put all the power to the ground of either kit at lower speeds (both would vaporize your rubber at any RPM in first gear @WOT) and the power advantage of the IC/higher boost would require you to get above that 4600 RPM or so in second gear (over 80 MPH before you got any improvement in output and then you might be playing catch-up) I think the non-IC kit is the way to go in a street car (the way I use it) and that is not even considering the substantial difference in costs for the full kit. Now if you wanna build a top-end track car, push more than that 5 PSIG of boost, or do the half-mile street racing thing, then sure, IC/more boost is a no-brainer. I just don't believe that a primarily street driven (front drive LS4) car can really use that much power.
Last edited by 06 SS; Oct 5, 2010 at 09:57 PM. Reason: changed 4000 RPM to 4600 and adjusted speed in second gear
Old Oct 12, 2010 | 07:39 PM
  #130
2005gxp's Avatar
Cheers
Sooooo price on the intercooler and everything else to upgrade?
Old Oct 13, 2010 | 05:08 AM
  #131
dro1dro1cars's Avatar
So the pics and videos are on facebook
Old Oct 13, 2010 | 05:48 AM
  #132
2005gxp's Avatar
yeah, whats your point? lol
Old Oct 13, 2010 | 05:46 PM
  #133
Dependind on what I see will determine If I buy
Old Nov 4, 2010 | 03:49 PM
  #134
1BAD06MCSS's Avatar
anybody get their turbo on yet?
Old Nov 4, 2010 | 08:52 PM
  #135
torchred'10's Avatar
would this work with a buick lacrosse?
Old Nov 4, 2010 | 09:16 PM
  #136
2005gxp's Avatar
with the 5.3l v8 i dont see why it wouldnt.
Old Nov 16, 2010 | 07:12 PM
  #137
Aaron_Provost's Avatar
can we get an update on additional options and pricing with this kit
Old May 28, 2011 | 07:22 PM
  #138
RedRiderSS's Avatar
So what's the latest? Those who got the turbo set up how do you like it?
