ls4 block capabilitys
Old Aug 19, 2010 | 08:34 PM
impalass3742's Avatar
Default ls4 block capabilitys
im curious what can the ls4 block handle. i have a chance to get a ls4 motor out of a wrecked grand prix for 800 and i want to fully forge it and use the turbo set up and run around 20lbs of boost. also what will the front sub frame handle and the axles? i know i will have to get a built trans. there is just something about making a front wheel drive 4 door car dip into the low 10 high 9 area that intrigues me. a 4 door family car that can eat a zo6. hmmmm
Old Aug 19, 2010 | 08:50 PM
Hawkins04's Avatar
talk to rossko i think he is running about 12 psi on a turbo plus 100 shot on e85
Old Aug 19, 2010 | 09:28 PM
LS4_DeltaV's Avatar
The LS4 with a forged bottom end, which you will have to have custom pistons made, will reliably make 800 crank horse.
But there is no 4T65E HD that will hold that type of power. So far we have one holding 650 just fine. With one more mod we feel we will move that up to 750 crank horse.
Thats the current limitation.
cheers
Old Aug 19, 2010 | 10:16 PM
AlabamaGuy's Avatar
Um....custom pistons?
Old Aug 20, 2010 | 07:06 AM
LS4_DeltaV's Avatar
Is somebody now making a piston set for this motor?
I've looked all over.
The only thing i found was Ross piston will make a custom set to your specs.
This is what Mark had to do...
Please share if you found an off the shelf set.
Cheers
Old Aug 20, 2010 | 07:39 AM
AlabamaGuy's Avatar
Any pistons made for a 5.3L should work fine.
Old Aug 20, 2010 | 02:59 PM
neilownz's Avatar
They need to be the right size for the smaller bore.
Old Aug 20, 2010 | 03:04 PM
LS1 Racing's Avatar
Dude wants to run 20 PSI. He won't be able to do that the LS4's 10:1 compression, so a low compression piston is a must.
Old Aug 20, 2010 | 05:45 PM
Hawkins04's Avatar
i dont think the trans will be strong enough?
Old Aug 20, 2010 | 06:13 PM
AlabamaGuy's Avatar
Yeah, 3.78" bored sleeve honed out would be what, 3.79" or 3.8"? I'm pretty sure there are aftermarket pistons for small bore LS motors. Don't hold me to it but I'm 99% sure someone makes them.
Old Aug 20, 2010 | 08:01 PM
LS4_DeltaV's Avatar
I've called Carrilo, Diamond, Ross etc....
None of them make a piston for our cars. Some of them had never even heard of an LS4.
Thats the bad news. The good news is Ross will make you a custom set for about 200 bucks more than a standard set. Not so bad.
Cheers
Old Aug 21, 2010 | 12:33 AM
AlabamaGuy's Avatar
Cheers
Try telling them you need a piston for a 3.78" LS1 bore
Old Aug 21, 2010 | 09:32 AM
LS4_DeltaV's Avatar
The deck height is different
Old Aug 21, 2010 | 11:53 AM
neilownz's Avatar
Shouldn't make a difference. Just use ls4 length connecting rods.
Old Aug 21, 2010 | 11:54 AM
SidewaysV8's Avatar
I know of a big block Ford Pinto that can eat a Z06, but what's the point?
Old Aug 21, 2010 | 12:36 PM
LS1 Racing's Avatar
That's so 80's! It seems like very car mag did a story on how to build a 460 Pinto back in the day.
Old Oct 21, 2010 | 07:39 PM
dro1dro1cars's Avatar
so what is the piston size and who should i get them from
Old Oct 21, 2010 | 09:29 PM
Haulin_Ls4_GxP's Avatar
Shouldn't you be able to use the 5.3l truck pistons?
Old Oct 21, 2010 | 10:10 PM
Super LaX's Avatar
cheers
This setup seems to hold together pretty good with 900 hp. Maybe because of the lighter vehicle weight and less torque possibly?
http://www.gmtunersource.com/gmracin...g/brianballard
http://www.gmtunersource.com/gmracin...jasonwhitfield
http://www.gmtunersource.com/gmracin...ng/ericanocita
Old Oct 22, 2010 | 12:26 AM
AlabamaGuy's Avatar
Yes. To the best of my knowledge, and everyone I've talked to about it.
