Weird noise
EVERY time i pull off after starting my car there is a noise which sounds like traction control kicking on it lasts maybe 2 seconds.....there is little vibration from the brake peddle but absolutely no braking at all i don't think it is the traction control because it does not make the same sound when the tires do get loose....anyone have any ideas?
Anyone with a GXP have the same noise?
If you have a whining noise while turning, it's a problem with the power steering. Check the fluid level!
I just bought the dam thing
