6T75 6 speed conversion
Old Mar 27, 2015 | 07:30 PM
  #101
91parkave's Avatar
Moderator
Originally Posted by fieroguru
Adapter plate on the LS2 to convert from the RWD SBC pattern to the GM Metric pattern:
That's what I figured had to happen knowing they were different.
I wish I had more time and money to grab a 6t75
Old Mar 28, 2015 | 09:24 AM
  #102
TrueBlueGTO's Avatar
Have you got the full kit to mount the starter, or willing to sell me the prototype oil pan?
Old Mar 29, 2015 | 03:20 PM
  #103
fieroguru's Avatar
I had zero involvement with the LS2/6T75 swap, but I am familiar with the details of it.
Old May 8, 2015 | 06:44 PM
  #104
GXP25's Avatar
The 6T75 will not bolt up to the LS4. The 6T70 will though.
The 6T75 has a four bolt torque converter with the new GM High Feature bolt pattern.
The 6T70 has a three bolt torque converter with the GM metric bolt pattern.
Old May 10, 2015 | 07:54 PM
  #105
fieroguru's Avatar
Yeah, it looks like I didn't pay enough attention to the adapter plate. The new pattern on it isn't the GM Metric one, but the High Feature V6 one. Here is a pic of the transmission he used (clearly not the GM Metric pattern):
I did some checking and couldn't find any applications with the 6T75 with the GM Metric pattern. The 6T70 did some in both the GM Metric and High Feature V6 patterns.
Old May 11, 2015 | 04:57 AM
  #106
Mike The Canadian's Avatar
I don't imagine the 6T70 holding up to the LS4 eh.
Every time I roll through WOT in this car I think damn wouldn't an extra gear or 2 be great!
Old May 11, 2015 | 09:44 PM
  #107
fieroguru's Avatar
You could swap the guts from the 6T75 into the 6T70 case. The ribbed case was one of the differences, but you would get all the other good parts.
And it is a lot of fun rowing an LS4 through 6 gears... with a manual.
Old May 11, 2015 | 11:11 PM
  #108
91parkave's Avatar
Moderator
What I do like though is grabbing a 6.2 or 6.0 and dropping it on a 6t75 and fit all the ls4 accessories on and moving out.
Old May 15, 2016 | 11:04 PM
  #109
BlownGP's Avatar
So I guess the general consensus is it won't work in a W-body?
I would love to have that trans with my L67.
Old Aug 26, 2018 | 10:01 PM
  #110
LSDream's Avatar
Default LS4 to 6t75 transmission
Im hoping this can still be possible... I have both a 6t70 and a 6t75 but i want to put the ls4 into my 2008 Saturn Outlook... The 3.6 doesnt quite cut it plus needs a rebuild or replacing at this point and imo not worth buying another if i can buy an ls4 instead. Last comment I seen was a snag about it fitting into the w body with the mods. My question is it possible to make it fit in the Saturn?
Old Sep 1, 2019 | 10:39 PM
  #111
pshojo's Avatar
And it is a lot of fun rowing an LS4 through 6 gears... with a manual.[/QUOTE]
You have LS4 with 6spd manual? link ? more info.
Old Sep 26, 2019 | 10:26 PM
  #112
fieroguru's Avatar
You have LS4 with 6spd manual? link ? more info.[/QUOTE]
Sorry, didn't see this until today....
https://ls1tech.com/forums/conversio...peed-swap.html
