Another Tranny up in smoke :(
Old Apr 10, 2011 | 01:14 PM
Jayzvette's Avatar
Default Another Tranny up in smoke :(
I'm starting to get the tell tail signs of either transmission failure or torque converter failure... maybe both. It's starting to surge on the highway between 45-65 mph. The car is way out of warranty with 101k on it. Anyone know how much it would cost to replace either component or both?? Trying to weigh my options as we really like this car......
Old Apr 10, 2011 | 02:25 PM
SScali's Avatar
This might be happening to me as well on the highway what do you mean by surge though?
Old Apr 10, 2011 | 03:19 PM
Jayzvette's Avatar
the rpm's jump up and down 300-400 rpm's when just cruising along. The car seems to shift fine, so mine maybe just the converter? I guess I'll find out Tuesday when I bring it to the dealer..
Old Apr 10, 2011 | 03:20 PM
blakss's Avatar
Replaced and upgraded like 3500
Old Apr 10, 2011 | 03:22 PM
Jayzvette's Avatar
Aftermarket or through the stealership?
Old Apr 10, 2011 | 04:17 PM
rvd9431's Avatar
tripleedgeperformance.com
buy a trans from him, is this your first trans failure??
Old Apr 10, 2011 | 04:35 PM
SScali's Avatar
Awh no!!! this sounds like my problem as well because with me it shifts fine but when I enter the highway and I am at around 60 mph the rpms jump up and down to lower rpms and it only happens in highway.
Old Apr 10, 2011 | 05:48 PM
Jayzvette's Avatar
Yup, First one...... I'm surprised it made it this long seeing how many people are having failures with such low miles.
Old Apr 10, 2011 | 07:22 PM
rvd9431's Avatar
i thought that was my problem, but it was just the TCC unlocking when Id jump into DOD mode.....make sure thats not what it is first
Old Apr 10, 2011 | 08:11 PM
Haulin_Ls4_GxP's Avatar
does it do it with CC on? if so then yes its a trans issue if not then no the trans is fine. Also DOD can cause a slight surge feeling when kicking on and off
Old Apr 10, 2011 | 08:50 PM
JC05GXP's Avatar
I saw that recently going about 75mph it kept trying to go into DOD but too much load so it never really did. I increased speed a bit and it stopped. Every time DOD engages or disengages the TC unlocks witch will jump your RPM's by like 300-400ish
Old Apr 13, 2011 | 08:43 PM
Jayzvette's Avatar
Yup does it with cc on...... Dealer says the torque converter is junk. Problem goes away when the tech manually locks it up with the tech2. They will know better on what else is wrong when they drop the pan.
Old Apr 26, 2011 | 05:48 PM
Jayzvette's Avatar
Well, had the torque converter replaced......Trans lasted about 30 miles then decided to **** the bed...... now it's back at the dealer for a trans tear down.... yippie ya hooooooo this is starting to get expensive....
Old Apr 26, 2011 | 06:54 PM
rvd9431's Avatar
ya whoever told u it was just the TC that was bad is a moron, when the TC goes bad its because of the clutch inside burns up and sends metal shavings throughout the trans that destroy the rest of the clutches and valves
When they rebuild or replace, dont let them tell you you can reuse the TC that they just put in, you need another new one, demand it if they say otherwise
Old Apr 26, 2011 | 07:27 PM
vroom_vroom's Avatar
3500 is way ****** high especially if they just want to rebuild it to stock, i was quoted 14-1800 and they are doing the same stuff that dave dose at triple edge i will let you know my total cost by Friday the im out to destroy some tires
Old Apr 26, 2011 | 08:54 PM
rvd9431's Avatar
i got quoted 1695 from a local trans shop for a rebuild installed WITH hard parts included and sonnax sure cure kit installed, dealerships are a ripoff
