tranny record?
Old Jun 21, 2011 | 12:25 PM
  #41
LS1 Racing's Avatar
Originally Posted by nat120
Dave at TEP recommends dropping the pan and changing the filter. No flush! When you drop the pan only the fluid that comes out natrually should come out which is about 50% this way it does not shock the system of the tranny. When you refill it, it will have 50% old fluid and 50% new. He informed me that if you go past about 23,000 miles and dont change it he does not recommend changing it at all. I just have my tranny rebuilt by him about 4,000 miles ago and it was a huge difference. I had the gears changed to 3.29 and a hardened input shaft. I have been loving it.
Originally Posted by EmersonHart13
23,000 eh? Well I am just over 36 now so I should just ride it out?
I hadn't asked Dave about service interval. Is he saying that we should change it out at about 20,000?
I have about 17,000 since my TEP-fortified rebuild. I was thinking about doing a fluid change when it gets to 20,000. So far, my fluid (with the help of a huge cooler) is still pink and clean, but I'd rather be safe than sorry.
Old Jun 21, 2011 | 03:16 PM
  #42
EmersonHart13's Avatar
I am sure on a TEP trans you can do whatever. Mine is stock...
Old Jun 21, 2011 | 03:42 PM
  #43
Just got an email from Dave. He recommends a service interval of 24-30k. Filter change preferred over the flush. I am coming up on 40... I am not sure if I want to ride it out or change it... Decisions Decisions!
Old Jun 21, 2011 | 07:26 PM
  #44
nat120's Avatar
Sorry I had to make a correction to my post it is 24-30K mile range and a pan drop to service the fluid and filter is the safest way. Per Dave. I would change it now and you should be fine.
Dave at TEP recommends dropping the pan and changing the filter. No flush! When you drop the pan only the fluid that comes out natrually should come out which is about 50% this way it does not shock the system of the tranny. When you refill it, it will have 50% old fluid and 50% new. He informed me that if you go past fluid change intervals in the 24-30K mile range and a pan drop to service the fluid and filter is the safest way and he does not recommend changing it at all. I just have my tranny rebuilt by him about 4,000 miles ago and it was a huge difference. I had the gears changed to 3.29 and a hardened input shaft. I have been loving it.
Old Jun 22, 2011 | 11:05 AM
  #45
Anniversary "Z"'s Avatar
Originally Posted by TheJPGXP
Triple Edge Performance. Ask for Dave.
Is it the "High Performance Street/Strip" Transmission that you guys all swap to?
Old Jun 22, 2011 | 11:27 AM
  #46
TheJPGXP's Avatar
Idk, I'm still on my 2nd stock transfer. I'll be getting whatever the best package is, I forget.
Old Jun 22, 2011 | 11:55 AM
  #47
The stocker you swapped in, was there anything done to it at all?
I'm just curious cause the difference between their rebuild and street/strip is only about $200 and wonder if just beefing up the internals on my own wouldn't be just as beneficial as opposed to spending $1700+
Old Jun 22, 2011 | 12:07 PM
  #48
TheJPGXP's Avatar
It's a GM reman.
Old Jun 22, 2011 | 12:13 PM
  #49
Brangeta's Avatar
What is the stock ratio?
Old Jun 22, 2011 | 12:15 PM
  #50
TheJPGXP's Avatar
2.93 (filler so this will post)
Old Jun 23, 2011 | 07:01 AM
  #51
DavidGXP's Avatar
im in the 12's with stock trans at 55k. i have changed the fluid twice. no problems yet.
