H/c/i/
Old Jun 5, 2011 | 10:57 AM
sky's Avatar
sky
Default H/c/i/
Whats the et, and dyno numbers should I look 4 out of my 06 SS MC. Im going wit 218/220 pat g cam, 90mm ls6 int, 90mm tb, fender mount cai, dt headers, stage 2 tsp ls6 heads milled 0.30, flowmaster 3in. cattless w/o res. exh., 160 thermo. And I am looking into a stall converter, might go wit a 3200,26in. slicks, and a efi dyno tune. lokkin 4 feed back fellas, Thanks! ! !
Old Jun 5, 2011 | 11:09 AM
1BAD06MCSS's Avatar
with those mods, you will be looking at low 12's depending upon how good of a driver you are.
Old Jun 5, 2011 | 11:46 AM
94ss06gxp's Avatar
you wont make it much past your launch if you run your stock trans.. lol
Old Jun 5, 2011 | 11:41 PM
sky's Avatar
sky
Default Wow
Is da stock tranny dat garbage? Will the stall converter kill the tranny even wit a cooler? and where can I get a built tranny 2 handle the power? ? ?
Old Jun 5, 2011 | 11:43 PM
sky's Avatar
sky
Default 12's?
Im hoping 4 some high 11's b4 I hit it wit da Nos! ! !
Old Jun 6, 2011 | 02:45 PM
DavidGXP's Avatar
Stock trans is fine with a shift kit and cooler.
I haven't broke mine yet.
Old Jun 6, 2011 | 03:12 PM
94ss06gxp's Avatar
I guess as long as you don't baby your trans you should be fine. If not call Triple Edge Performance. . .
Old Jun 6, 2011 | 04:40 PM
sky's Avatar
sky
K, thanks fellas. What do yall think about the 3200 converter in a stock tranny? ? ?
Old Jun 6, 2011 | 05:26 PM
DavidGXP's Avatar
You should seriously consider having the trans gone over.
I am waitng on my PI converter. It's a 3000-3200 stall and costs about 800.00
My Transmission will be getting re-done once the converter gets here with a 300 input shaft, 3.69's, extra steel in the 2nd clutch and 3rd gear z-pack. Valve body solenoids will be replaced and valves/springs/sleeves will be replaced with sonnax booster kits. Rebuild kit came with trans-tech gasket and seal kit which use's improved seals and related stuff.
Everyting costs about 2300 shipped and will be about 1000 to rebuild with the parts listed above.
Contact Dave for parts.
The Engine parts you wanna use will be a clone of my build, so.. yes, you'll be in the 12's or better with a 1.9 or better launch. MPH will be around 114 or so.
Old Jun 7, 2011 | 01:31 AM
sky's Avatar
sky
Awesome feed back fellas, Thanks a ton! ! !
Old Jun 7, 2011 | 12:36 PM
06silverss's Avatar
That sure sounds like a heck of a build! Good luck! Can't wait to hear some numbers!
Old Jun 7, 2011 | 12:45 PM
LS1 Racing's Avatar
Stock converter is like 2800 stall already.
Do a search of the trans threads and you'll learn that power and heat are not the primary killers of our transmissions. It's problems with the design and engineering.
On this topic, DavidGXP and I will agree to disagree. Shift kit and cooler are good insurance, but they do nothing to prevent our failures.
For the amount of power that you're going to be making, however, I would expect that even if your trans didn't have any flaws (known or unknown), it still won't last long.
If I were you, I would take DavidGXP's advice and call TEP.
Old Jun 7, 2011 | 01:46 PM
sky's Avatar
sky
Will do, thanks!
Old Jun 7, 2011 | 02:44 PM
DavidGXP's Avatar
Will do, thanks!
I just might do the trans overhaul myself so stay tunned. I've got the space and manuals, I just need to order a few tools.
Seatac trans is right down the street so I might take a few sub assemblies in for service. Plus they supply all parts to local transmissin shops, so I'm sure that I will be hitting up their warehouse for a few things here and there. I have done a few TH-350's
Since my trans is still good, I shouldn't have to worry about too many extreamly worn items. This is something you might wanna consider too. Much cheaper too upgrade a working transmission then to fix and upgrade a broken one.
By doing the work myself I will know what has been done and learn about it's current condition. Something that I will take my time on.
http://www.tripleedgeperformance.com/
http://www.sonnax.com/product-lines/...%5Bunit%5D=231
http://www.converter.com/ These are the converters that Dave use's. What I ordered.
http://www.bonnevillepro.com/forums/...hp?f=28&t=3218 Great write up, and detail of home trans rebuild.
Old Jun 7, 2011 | 03:19 PM
LS1 Racing's Avatar
You could make some serious $$ if you started doing 4T65-HD upgrades on the side! With Dave @ TEP working on a 1 month turnaround, you could really clean up on the west coast business!
Old Jun 7, 2011 | 03:40 PM
DavidGXP's Avatar
trans rebuids, cam and intake swap, and order a bunch of trinitys and use lews cusoms tunes. slp,zzp, davidgxp.. lol
Old Jun 7, 2011 | 06:18 PM
D J Real's Avatar
and DP could detail them when your done
Old Jun 7, 2011 | 08:21 PM
DP 08 GXP's Avatar
lol true true
Old Jun 8, 2011 | 10:07 PM
DavidGXP's Avatar
Originally Posted by DP 08 GXP
lol true true
That would be really cool.
341tq?
Old Jun 9, 2011 | 03:29 PM
Sittingmongoose's Avatar
as far as power goes. You should be making like 330hp, 370tq. Maybe a little better. Might want to go with a little bigger cam if you can. Also REPLACE YOUR TRANS!!!
