P0121 Code Help???
Old Oct 3, 2011 | 07:10 PM
Uptown_GXP's Avatar
Default P0121 Code Help???
My CEL light came on and I went to autozone got it scanned. Came up with P0121, Throttle position sensor. I had the GXP in the shop and they checked every single sensor according to procedure. MY mechanic told me he tested over 10 different sensors and veverything checked out ok. He said I would either need to take it to GM or star with cleaning the throttle body out.
Before I go broke goiing to GM I really would like to know if anyone has had this problem or could provide some guidance. I have a K&N on there as well if that makes a difference.
Thanks
Old Oct 3, 2011 | 07:51 PM
SRTH8R's Avatar
I would think something like that should be covered under powertrain. May want to put the stock intake on so they have nothing to complain about. Eliminate excuses.
Old Oct 4, 2011 | 03:59 PM
Uptown_GXP's Avatar
Will they decline t work on it completely if the K&N is on there?
Old Oct 4, 2011 | 04:33 PM
SRTH8R's Avatar
No, just some dealers are mod friendly and some aren't. If it was the MAF I would say remove it for sure. But you should be fine.
Old Oct 4, 2011 | 05:35 PM
LS1 Racing's Avatar
Remove the K&N before going to the dealer. If the dealer wanted to be a stickler, they could deny warranty coverage, and you'd have a tough time fighting it. They could argue that the oil from the K&N CAI caused the failure, since the TB is connected to the intake via the MAF. Now, we all know this is bullshit, but they would at least have an argument.
Save yourself the headache and make the car as stock-looking as possible before taking it in.
Old Oct 29, 2013 | 09:40 PM
mostmint's Avatar
My Impala is now giving the same code. It comes and goes. Anyone else have this repaired?
My MAF looks quite clean. I'll probably start cleaning the MAF, then replacing the pedal position sensor.
Old Nov 25, 2015 | 10:14 PM
mostmint's Avatar
I ended up replacing the pedal position sensor. I got one from a junkyard V6 car and it worked fine. The sensor is integral with the pedal so I ended up replacing the whole thing.
Old Nov 25, 2015 | 10:53 PM
superglide9375's Avatar
yea but i think it won't throw code with stock cai on there,if u get a tune u could tune for that as i had to do with lew
Old Nov 26, 2015 | 05:14 PM
Sint3k's Avatar
Thanks
No offense, but the chances of your mechanic knowing how to glitch test the sensors is likely 0.
So with that said, if you clear the code and it does not return then its an intermittent issue. With that said, you need to hook up an oscilliscope to sensor signal wire for the throttle posistion sensors, and the throttle sensors, and slowly go through the range on each one and watch for "glitches" and "Drop outs", and also move around any wiring. According to the service manaul, this code is specific to the throttle body and not the pedal, despite the generic code listing. So you can likely skip testing the pedal.
You can do the "Service manual way", which is not my ideal way of testing these issues, but its a good place to start. Which ive attached below.
Old Nov 26, 2015 | 07:43 PM
Sint3k's Avatar
CONDITIONS FOR RUNNING THE DTC
DTCs P0102, P0103, P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0128, P0335, P0336 are not set.
The engine speed is more than 450 RPM .
The engine coolant temperature (ECT) is between 70-125°C (158-257°F) .
The intake air temperature (IAT) is between -7°C and +125°C (+19°F and +257°F) .
DTC P0121 runs continuously when the above conditions are met.
CONDITIONS FOR SETTING THE DTC
The TP sensor 1 disagrees more than 9 percent from TP sensor 2.
The TP sensor 1 disagrees more than 9 percent from the predicted value.
The above conditions are met for less than 1 second .
Old Sep 11, 2016 | 09:10 PM
mostmint's Avatar
I agree with above comments regarding the pedal. It is a bit confusing to me but the code has returned. Car just flipped 100k. Problem is still intermittent though more on than off lately
Old Sep 14, 2016 | 06:58 PM
mostmint's Avatar
After some investigating I learned P0121 was due to the computer figured out a variance in intake air speed. This made me believe this could be caused by a dirty mass air flow sensor. So I bought cleaner for the MAF and the throttle body and cleaned them.
The MAF I removed and sprayed, the throttle body I cleaned in place with a rag I sprayed cleaner on to wipe down the inside on the blade and where it seats.
The check engine light went out shortly after and has been out for a day so far.
Old Sep 14, 2016 | 07:09 PM
Sint3k's Avatar
Yea pretty sure you are confusing P0121 with P0101....
Cleaning the MAF will not resolve a P0121... only a variance in the 2 throttle sensors will create the code P0121......
Old Sep 15, 2016 | 07:45 PM
mostmint's Avatar
Pretty sure I can read.
Not making this stuff up.
Old Sep 15, 2016 | 10:12 PM
Sint3k's Avatar
I got this thread mixed up with another thread I'm helping someone with,
It is possible for the MAF to read incorrectly and cause the predicted value to be incorrect and not match the actual position of the throttle body.
What g/s is the MAF reading at idle and at 3000 RPM's ? Also, what is your fuel trims at idle and at 3000RPMS.
