GXP Rattle Front End
Old Oct 6, 2011 | 01:24 PM
JKG's Avatar
JKG
Default GXP Rattle Front End
2008 GXP with 53000. Earlier this year an odd noise, rattle, started coming from the front of my car. I did some low level testing within the car to try and determine what was making the sound. Here are some details on that:
  • Starts around 35-40 mph, presumably when going it to 3rd.
  • Stops when coming to a stop at almost precisely 15mph, presumably shift to 1st.
  • While cruising shifting into neutral it stops.
  • While using TapShift seems to stop.
  • While cruising, bliping the throttle stops it for a second and then returns.
Now I originally though this was a tranny issue because of it going away while in neutral and stopping at exactly 15mph at every stop. As well as general tranny issue with the LS4 and the 4T65E-HD. However the tranny is still responsive, meaning it hasn't changed since I first got the car.
After digging through this site I came across several threads that mentioned a similar sound that ended up being the timing chain and it's relation to AFM. Here is a recording of the noise I did several months ago.
http://www.youtube.com/watch?v=B1-b-avFAAY
For those of you that have or had a confirmed timing chain issue is the noise in the video what you were hearing?
https://ls1tech.com/forums/ls4-perfo...ing-my-ss.html
https://ls1tech.com/forums/ls4-perfo...ing-ideas.html
https://ls1tech.com/forums/ls4-perfo...isy-trans.html
