Fluid Leaking
Old Mar 31, 2012 | 06:07 PM
KurtMCSS's Avatar
Default Fluid Leaking
Found a puddle in my garage before I left out to go to work. Color is little reddish but looks watery. Coming from the left side of the bay (by the front right tire). How would I know what type of fluid it is? Also noticed a erratic ticking/clicking sound, similar to the clicking sound a gas stove makes when your igniting the flame when accelerating. Checked my tranny fluid, an oil. Dip sticks look ok. Any ideas? Thanks for any help.
Old Mar 31, 2012 | 06:39 PM
TheBlizzard's Avatar
Power Steering maybe, not many other fluids that are redish colored.
Old Mar 31, 2012 | 07:06 PM
baltsk8er69's Avatar
Check where the trans cooler lines go into the trans.
Old Mar 31, 2012 | 11:40 PM
06MonteSS's Avatar
LS1Tech Sponsor
could be the drivers side axle seal leaking, in which case yes, it would be tranny fluid....
just had both of my axle assemblies replaced last week, and my drivers side axle seal was shot too - causing a tranny fluid leak....
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Apr 1, 2012 | 02:05 AM
vroom_vroom's Avatar
its power steering, you can (and i do) use trans fluid instead of power steering fluid. but you CANNOT use power steering fluid as trans fluid. they are basically the same thing but the trans fluid has different properties to it.
fwiw atf makes for a near perfect gun oil
Old Apr 1, 2012 | 02:29 AM
Barnett92's Avatar
It could be your blinker light fluid
Old Apr 1, 2012 | 07:43 AM
Jeez barnett blinker fluid? those blinkers are sealed its obviously headlight fluid!!!
Old Apr 1, 2012 | 08:48 AM
KurtMCSS's Avatar
Thanks for the replies. Narrowed it down to power steering and coolant. Couldn't really tell at night, gonna jack it up today and see whats going on. Don't think it's tranny fluid.*Fingers crossed* (I need this car to make it too a 100k mi before I rebuild anything) Not dark enough to be. Looks like a pump or a bad hose needs to be replaced. Headed to the shop tomorrow to get a write up. @06MonteSS how much was it to get it fixed? @Barnett92 @baltsk8er69 -___- lol
Old Apr 1, 2012 | 09:19 AM
All jokes aside it very well could be those lines that come out the front of the trans. They leak on 105% percent of 4t65e's. The fluid might appear watered down but powersteering is slightly more clear no reddish tint unless a previous owner added trans to ps.
Old Apr 1, 2012 | 11:07 PM
Barnett92's Avatar
I hope you find your problem and get it fixed, didn't mean any offense.
Old Apr 1, 2012 | 11:10 PM
LS1 Racing's Avatar
I'm gonna bet on power steering fluid.
Old Apr 2, 2012 | 01:30 PM
KurtMCSS's Avatar
Drum roll.... It's the water pump. Local shop wants 170 for labor 265 for parts. Not bad but I feel like I can do better.@Barnett92 no offense taken man. Im not that sensitive. I'm just glad its not the tranny. Going to Internet shop around for the pump and see what I can do.
