'07 Impala SS clips after having it tuned.
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
I really wanted to completely top it out and I was soo close... friggin cars on my racetrack
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Yea I think thats just about all of lights, no cat is the check engine light and aftermarket wheels is the tire pressure sensor light... and then I had the traction control off too, yet another light haha.
Put it like this, get the biggest one you can put under there. A transmission shop would normally install it for like 100 dollars.
I haven't looked too closely at the LS4, as I didn't install my trans cooler yet.... but the way I had it on my L67, I removed the trans lines from the radiator and double-clamped the flared ends to hoses going to my trans cooler, which was mounted in front of the radiator. Doing it that way keeps the trans fluid away from the hot coolant going through the radiator and isolates it in its own cooler.
Some may not agree with it, as there are a couple drawbacks.... i.e., in cooler temps (winter), it takes longer to heat the trans fluid up. Cool fluid is good, but too cold is not.
2nd drawback, is now you have hoses/hose connections that can fail and your trans would be toast by the time you realized you have a major leak.
I never had a trans issue with that car over the 5+ years I owned it as a DD...and it was probably mid-high 12sec power (13.1 @ 108 with a shitty 2.2 60' on winter tires) for most of those years.
