Won't start
- From what I read the shift indicator in the DIC did not work prior to the R&R
- From what I read the ECM sometimes prior to the R&R did not show up at the ODB port.
- From what I read the remote lock/ unlock works, but no start with key. Did you try to start the car with the remote from outside the car?
Please tell me as detailed as possible how the R&R was accomplished as in battery connected/ disconnected , key in ignition and in on/off pos. , thru the top/ removal, wiring harness handling and so on. Do you still have the old trans there with you?
It was pulled through the bottom, 5 ground wires, starter wires, EBCM connector, VSS, unidentified connector on shift cable bracket, MAF, front ABS sensors, and throttle body were disconnected.
Battery was disconnected prior to starting the process, key was out of the car.
No wires appear to be damaged.
The remote start feature on this car stopped working a long long time ago. I did have trouble connecting a scanner before (Flashscan v2) but i don't rememeber the specifics, i believe it was most likely the same problem.
As far as I know the shift indicator did work prior to the install. The owner of the car wouldn't remember, first he said no, then yes.
top row (wider portion)
1 2 3 4 5 6 7 8
9 10 11 12 13 14 15 16
(narrow portion)
Ring pin 16 to a ground (+12v) 16 being+12v
Ring pin 16 to pin 4 (+12v) 4 being a ground
Ring pin 16 to pin 5 ( +12v) 5 being a ground
Ring pin 2 to a ground (+3.5-7 v)
then set to read resistance and place the red lead on pin 6 and the black lead on pin 14 and give the resistance found. (around 60hms)
Then I need you to reboot the ECU (it may be hung) To do this simply remove both batt terminals (first neg then pos) then depress the brake pedal. wait 10 min and depress the pedal again, then put the pos back and then the neg. Now try to read the ECU again and/or start it.
Pin 16 to ground, and pin 16 to 4 or 5 all give battery voltage.
Pin 2 is unused.
Pin 6 to 14 gives 115.9 ohms. Per my diagram it looks like it should be 120 ohms.
correction: with the key ON the resistance shoots way up. Key off its ~120ohms.
I also just have a few printouts from alldata.
