New Turbo GXP...
Old Nov 20, 2013 | 03:56 PM
  #81
GXP25's Avatar
Originally Posted by 92builtbird
Are there any performance loses due to the cts-v swap? I know there is more rotational mass with the bigger rotor, but I'm not sure how noticeable it will be.
There is less brake fade.
I look at it this way: these caliper + rotor assemblies come on vehicles that have been tested time and time again so I don't see much of a performance loss.
Old Nov 20, 2013 | 04:40 PM
  #82
92builtbird's Avatar
Originally Posted by GXP25
There is less brake fade. I look at it this way: these caliper + rotor assemblies come on vehicles that have been tested time and time again so I don't see much of a performance loss.
I should have been more clear, I meant strictly speed-wise. I would hate to be losing tenths, but isn't the rotor only a pound heavier per side more than stock?
Old Nov 20, 2013 | 07:29 PM
  #83
GXP25's Avatar
GT500 front rotor: 26.2lbs - GXP front rotor: 24lbs
2009+ CTS-V/2010+ Camaro SS rear rotor: 24.05lbs - GXP rear rotor: 15lbs
Front CTS-V calipers weigh about the same as the GXP front calipers; I've weighed these personally. No clue on the rears.
Old Dec 1, 2013 | 08:25 PM
  #84
I cannot find the part number or size of the Banjo Bolt for the CTS-V Caliper. Been looking for days..
Can anyone help me out??
EDIT: Are they 10mm x 1.00 ??
Old Dec 1, 2013 | 08:33 PM
  #85
x11 nut's Avatar
You can use your stock GXP banjo bolts, but you either need to double up the thin copper washers or get extra thick ones - take another look at the pics.
Old Dec 1, 2013 | 08:46 PM
  #86
Gotcha, that'll do it then.
And for the Caliper bolts, did you mess around with CTS-V bolts, or just use M12 x 1.75 x 60mm bolts?
Old Dec 2, 2013 | 12:39 PM
  #87
Anyone??
Old Dec 2, 2013 | 12:59 PM
  #88
91parkave's Avatar
Moderator
Anyone??
Quoted from deunkies build on Gpf
-F-body or CTS-V Banjo Bolt
-CTS-V Caliper bolts
-ZZP Extended SS Lines
-CTS-V brake pads
-2005 Mustang GT500 Rotors (Centric One piece will work well and are CHEAP)Get it on RockAuto Part # 12061089
-4 x 12mm Flat washers (buy 2 packs of 5 just incase)
-4 x 14MM bushing
McMaster-Carr
Part# 6679K16 Desc: Metric Steel-Backed PTFE-Coated Brnz Bearing for 12 mm Shaft Diameter, 15 mm Length Price: $2.45/each Qty: 4 (Grand Prix's have 14mm bolts and CTS-V's use 12mm Bolts)
Old Dec 2, 2013 | 01:00 PM
  #89
GXP25's Avatar
Use the V bolts since they're the bolts that are made for the calipers.
You just need to use those sleeves. I have some extra sleeves if you want to buy them.
Old Dec 2, 2013 | 01:25 PM
  #90
x11 nut's Avatar
Looks like GXP25 has you covered - I ordered the M12 bolts and sleeves from McMaster-Carr. The sleeves keep it all centered, so they're a must unless you want to drill and tap the calipers for M14 bolts and you can use your GXP ones.
Old Dec 2, 2013 | 01:48 PM
  #91
Thanks guys. I have everything except the bolts (and the 1/2 washers)
Old Dec 2, 2013 | 01:54 PM
  #92
I can't locate the cts-v bolts online. I saw a thread on a Cadillac forum where a guy actually used a m12x1.75 60mm, because he didn't want to wait. Gxp25 do you know where I can order some online?
Old Dec 2, 2013 | 06:34 PM
  #93
GXP25's Avatar
P/N 18041878 - M12x1.75x55
You need four.
EDIT: You can get them at any dealership. I tend to get most of my GM parts from the dealership if it's reasonable enough. That way I don't have to deal with shipping costs. I only do that after checking their advertised price versus GM's true online price.
If I find myself being gouged, I tend to buy from http://www.group1autoparts.com
They tend to have some of the best prices and cheap shipping.
Old Dec 2, 2013 | 08:33 PM
  #94
P/N 18041878 - M12x1.75x55 You need four. EDIT: You can get them at any dealership. I tend to get most of my GM parts from the dealership if it's reasonable enough. That way I don't have to deal with shipping costs. I only do that after checking their advertised price versus GM's true online price. If I find myself being gouged, I tend to buy from http://www.group1autoparts.com They tend to have some of the best prices and cheap shipping.
Saweet. Thanks again.
Old Jan 17, 2014 | 09:43 PM
  #95
pontiacjeff's Avatar
So, the imited slip diff works good, huh??? I told you you'd like it.
Old Jan 18, 2014 | 05:46 AM
  #96
x11 nut's Avatar
Yes, it works great - waiting till I need tires for the smokey white burnout! I still need to get to the track for a test & tune, but after a ride - my trans builder wants to use them in all his performance builds.
Old May 16, 2014 | 08:25 PM
  #97
x11 nut's Avatar
Overdue update - this is what a fried 3rd looks like...
Old May 19, 2014 | 11:05 AM
  #98
severancej's Avatar
Man... Now what ya going to do?
So third that's up there 100- 140ish right? I know that was fun!
Old May 19, 2014 | 11:45 AM
  #99
ramairetransam's Avatar
more pics , and lets see some vids of this beast
Old May 20, 2014 | 08:00 PM
  #100
x11 nut's Avatar
The pic was from the tear down of my original stock trans - it didn't last long with the Turbo on it... just took awhile before I took apart to see the carnage.
I did a full performance build a year ago and its running strong.
