New Turbo GXP...
Old Jul 17, 2014 | 08:53 PM
  #101
turbo_Ls4's Avatar
^ good to hear shes going strong!
Old Jul 17, 2014 | 10:28 PM
  #102
Sint3k's Avatar
Originally Posted by x11 nut
Thanx! I'm going to have to replace the exhaust cut out cause its not working. Tested it before I installed it, now nada.. With it closed, boost is limited to about 6 psi. It still goes like stink, so not too concerned - I'd be way pissed if it stuck open!
How is boost limited when the cutout was closed?
Old Jul 18, 2014 | 07:26 AM
  #103
x11 nut's Avatar
I have stock exhaust past the down pipe which has plenty of back pressure as you build boost - with the cutout open, the pressure after turbo drops significantly and allows turbo to spool faster.
