New Turbo GXP...
Quick and nasty - they feel great, pedal response is very quick and definitely
stops hard!
For anyone else wanting to upgrade - don't bother with the washers from McMaster-Carr, they're too thick. The 1/2" fender washers from Home Depot (in orange bag) work perfect to center calipers on the rotors. \
I ordered a set of extended stainless lines from ZZperformance, but the ones for the rear don't work right on the rear GXP calipers. I had a set of Russell W-body stainless lines for my project car and the rear from that kit worked. Also, the ZZPerformance lines needed a double or thick brass washer to center the fluid port on the banjo bolts. Peep da pics
Now if I can get a long weekend to install the LS6 intake and ported TB.
Hope that helps.
McMaster-Carr
Part# 6679K16 Desc: Metric Steel-Backed PTFE-Coated Brnz Bearing for 12 mm Shaft Diameter, 15 mm Length Price: $2.45/each Qty: 4
Grand Prix's have 14mm bolts and CTS-V's use 12mm Bolts
Source info:
https://ls1tech.com/forums/ls4-perfo...brake-kit.html
http://www.grandprixforums.net/showt...+brake+upgrade
I got Slotted/ drilled rotors from Brakemotive.
Last edited by GXP25; Nov 19, 2013 at 09:59 PM. Reason: Corrected the website. Brakeperformance, not brakemotive.
Do you happen to have a P/N?
I made my own brackets. I'm looking to get more made so stay tuned.
I'll update my brake thread with pictures later.
EDIT: It's brakeperformance.com and not brakemotive.com. I'll edit my other post.
