Best street Performance tire??
Old Dec 18, 2012 | 04:56 PM
ls1charged's Avatar
Question Best street Performance tire??
I'm due for some new tires and I wanted to get some of your thoughts and or experiences on a good performance tire that is good for everyday use/DD but at the same time have great traction for the occasional track usage? Or should I just get some DR's and ride around on those everyday lol
Old Dec 19, 2012 | 09:57 PM
08GXPGXP's Avatar
Everyone seems to tell me the nitto555s but honestly check out the s04 pole positions!! I'm pretty sure their bridgestone.. potenzas..
Search some 275 wides thatll fit a 8inch rim and poof who cares the brand. That's a meaty tire !!
I honestly want the perelli pzeros but the 18s I find for my gxp were super low profile.. like a 35.. and their almost 500 a piece.. awesome tire tho.. my buddy has them on a sick mustang.. he can barely even peel out
Old Dec 20, 2012 | 12:08 PM
UseAsDirected's Avatar
I'm very happy with my Pirelli P-Zero Neros. The other I was considering was the Bridgestone Continental Extreme Contact. Gotta have all-seasons here though.
Old Dec 20, 2012 | 11:00 PM
Vectus's Avatar
I had continental DWs when I had my ss, i went through a few different tires and these where surprisingly one of the best and for the price i couldn't be happier. I went through fire hawks, f1s, and BFGs.
Old Dec 21, 2012 | 08:28 PM
DuronClocker's Avatar
The S04's are my next tire. One of the rears is this (had to replace a flat), and in the spring I'll be replacing the other rear and the fronts.
If you're going this route, avoid the DWS and look for the DW. I'm definitely not impressed with the DWS on the car. Overall an "okay" tire but didn't excel at anything.
Old Dec 22, 2012 | 07:45 AM
Vectus's Avatar
I meant just DW but meant plural haha. They're summer tires but they also got me home when the roads were covered in ice and everyone else around me was sliding.
Old Dec 22, 2012 | 08:02 AM
I figured that was what you meant but just wanted to clarify
Old Dec 27, 2012 | 10:15 PM
hazards280's Avatar
I had Mich Pilot Sport A/S Plus's and they were amazing in the summer.
Old Dec 28, 2012 | 12:17 PM
DavidGXP's Avatar
I am still using the stock potenzas on the rear. They have over 67,000 miles on them and have never been rotated. (Obvious reasons).
The stock front tires were dam good and lasted for 30,000 miles. They would cut
2.0's on a sticky track. 13.9-14.0's all day (Tap shift). The stock tires are very expensive though, but are worth it IMO on a daily driver.
I am using 275/40/18 Hankook V12's which took my 0-60 down to 5.2-5.3 sec vs 5.6-5.8 sec stock (using my Dashawk to record the 0-60 mph runs). My only mods at the time were 3" into dual 2.5" exhaust, CAI, and tune, so traction sucked with those mods using the worn potenzas.
A 275 wide tire is not recommended on a 8" wheel, but has worked pretty dam good for me. I have put 37,000 miles on my Hankooks and they should have been replaced about 5,000 miles ago. They are bald! (I run them with 30psi)
https://ls1tech.com/forums/ls4-perfo...on-follow.html
Read this before buying
http://www.caranddriver.com/comparis...mparison-tests
Old Jan 2, 2013 | 03:35 AM
V8ImpSS's Avatar
I really like Toyo Proxes series tires, the new T1 sport is uber sticky. You also can't beat a Pirelli P Zero or sportcontact Continental's. I like a tire that has ride comfort in mind, as all of these do, due to their sidewall design.
Old Jan 7, 2013 | 08:07 PM
AlabamaGuy's Avatar
Direzza DZ101 is the best I've ever ran across. Once they heat up they get very, very sticky. I liked the hankook ventus v12 k110 evo's a lot as well, seemed to last longer at the sacrifice of some traction. That being said, they performed really well in the corners.
Old Jan 13, 2013 | 11:30 AM
gagt3100's Avatar
I just bought some old rubber tires but they had 100% thread on them, so I am in the same boat as you for new tires come spring. I have been having a hard time to find any drag radials that would fit a 18x8 rim.... So I think i am going to try out hankook v12's if I can not find a good radial setup :/
Old Jan 13, 2013 | 08:38 PM
Brian396's Avatar
Have you looked at the NT05?
Old Jan 14, 2013 | 12:02 AM
AlabamaGuy's Avatar
They aren't *that* sticky for a track tire. The NT01 is the way to go, though. Although a Mickey Thompson would probably be best for drag racing. And yes, they do come in 18's.
Old Jan 14, 2013 | 03:12 AM
BlackImpSS's Avatar
The NT05R is going to be the best tire for drag racing from Nitto. The NT01 is more suited for road racing I do believe. Performance wise between the the NT05R and the MT isn't going to be huge. Or you could always go with the NT555R it's an in between tire(only DR you will get 10-15k miles from) the NT05R and the MT plan to replace about every 5K miles. The NT555R are great tires and extremely sticky, but they do require a good burn out to heat up. A few of my fbody friends have cut 1.6x 60' on said tire, but only when heated properly.
Old Jan 15, 2013 | 06:46 PM
gagt3100's Avatar
Ordered some hankook v12 evo's 275/40/18 412 for 2 at my door
Old Feb 17, 2013 | 10:18 AM
rkvette's Avatar
Wink Tires
i agree with vectus / continentals / no noise / very good handling !!
Old Feb 17, 2013 | 03:00 PM
06mistreSS's Avatar
I've also heard the same about Nitto. I have Pirelli P Zero Neros on my Monte and they've been great. I'm up for a new set of tires soon and am looking closely at the Michelin Pilot Super Sport and am also considering the new Pilot Sport A/S 3 (all-season tire, summer 2013 release). Michelin has been recommended to me multiple times and their ratings look very good. Also considering, but lower on the list, the Pirelli P Zero Russo and the Goodyear Eagle F1 Asymmetrical.
Old Feb 24, 2013 | 12:47 PM
bigboymike68's Avatar
I had the P Zeros on my 06 SS and got nothing but wheel spin from them. I have Nitto 555R Extremes on my car now 255/45/18 all the way around and I have to say they a a great tire for grip especially when its hot. I have driven them in rain and the grip is acceptable to good. I have driven them in 3" of snow and was surprised they drove as well as they did.
Old Feb 28, 2013 | 12:27 PM
crich88848's Avatar
Just put some Nitto Motivos on yesterday and all I can say is WOW. I put about 60 miles on the tires yesterday and I can honestly say I have never felt more confident driving a car. We got hit with the snow storm and the roads were still pretty bad yesterday and I was flying through the snow with no issues at all. Usually I have to let off the gas when changing lanes when there is snow built up between the lanes, but I was able to gun it into the next lane with no spin at all. When I got home I had to drive through about 5 inches of snow because I hadn't shoveled yet (I actually got stuck in the same snow that morning for about a half hour with the old tires on) and my tires didn't spin or slip once. I will see how they work out after I put some more wear on them, but as of right now I don't think I will ever put a different tire on my car. Oh and the Motivos also come with a 60k mile warranty which is amazing.
