Which head studs for a turbo build
Old Apr 1, 2013 | 12:20 PM
ls4_newbie's Avatar
Default Which head studs for a turbo build
Hi guys I was wondering if somebody could tell me which head stud I need to fit the ls4 block. I'm using the 317 heads if that makes a difference. The reason I ask is apparently there is a 11mm choice LQ9 and 12mm choice ls9.
Cheers
Old Apr 2, 2013 | 01:55 PM
Dom87SS's Avatar
id guess they are 11mm since a LS9 was not even released for sale years after the LS4 was killed off. call a machine shop or someone like ARP and they will be able to look it for you.
Old Apr 2, 2013 | 03:30 PM
91parkave's Avatar
Moderator
why are you using 317 heads IMO it would be better to keep the 243's and thicker head gasket for boosting
Old Apr 3, 2013 | 10:59 AM
ls4_newbie's Avatar
I'm using the 317 heads and the thicker head gaskets to lower the cores soon to be able to run more boost safely as when I read into boosting these engines you had to use a 9:1 comp ratio to to be able run over 15psi
Old Apr 3, 2013 | 11:50 AM
91parkave's Avatar
Moderator
I would disagree and 15 psi on this car is some serious power I hope you got money for a transmission and a. 1" gmr chain otherwise the power will never get to the ground
Old Apr 3, 2013 | 12:50 PM
ls4_newbie's Avatar
Yes the transmission is not an issue I'm basically buying triple edges catalogue of parts then when I have something to work with I have a company in the UK willing to make a Borg Warner 1" wide chain, failing that ill get adaptor plates made to fit a different box
Old Apr 3, 2013 | 04:40 PM
Brian396's Avatar
If you have E85 in your area, 10:1 and 15 psi would not be a problem.
Old Apr 3, 2013 | 08:18 PM
91parkave's Avatar
Moderator
Whoa dude if you have a line on those chains you're going to be rich look forward to the build man
Old Apr 4, 2013 | 04:04 AM
ls4_newbie's Avatar
Unfortunately mate in the uk E85 never took off and the only way to get it is from someone like vp fuels at about $120 a 4 gallon barrel
Old Apr 4, 2013 | 04:07 AM
ls4_newbie's Avatar
Thanks mate I'm gonna put these chains through some serious grief before we market them. But I'm wanting them to strong enough to take seriously high torque
Old Apr 4, 2013 | 04:42 AM
itsslow98's Avatar
I agree, id rather have the 243s. You can make the same power on 10psi with 243s as you would with 317s and 15psi its all in the tune.
Also if meth is available over there id strongly consider it for IATs and octane.
Old Apr 4, 2013 | 05:13 AM
91parkave's Avatar
Moderator
^^^^^^^ this.
Also if not denatured alcohol and distilled water will work 50/50 mix I'm sure you guys in the UK have that at hardware stores
Old Apr 4, 2013 | 05:37 AM
ls4_newbie's Avatar
Yeah I was planning on running with meth injection anyway so hypothetical sakes if I was to keep the 243 heads and run 10psi what sort of power would you expect to see. Just to be aware I'm running on aftermarket management anyway.
Old Apr 4, 2013 | 06:16 PM
itsslow98's Avatar
Hard to say without more details on the build. What size turbo, stock cam, stall etc.
Old Apr 6, 2013 | 09:04 AM
Brian396's Avatar
GXPJAY was getting 505 hp at 12 psi with windshield washer fluid injection. https://ls1tech.com/forums/ls4-perfo...-kit-sale.html
