Exhaust
Old Nov 23, 2014 | 12:41 AM
noobc6owner's Avatar
Default Exhaust
Car is on the dyno right now and tuner says the mufflers looked restrictive, what do people usually do to get better flow without buying a a whole exhaust system ? I was thinking to cut them off and just weld something up lmk thanks
Old Nov 23, 2014 | 02:35 AM
_zebra's Avatar
makes children cry
you can certainly just buy a muffler by itself & have an exhaust shop weld it up in place of the stocker. if it's performance & less restriction you want, look for a straight-through design as opposed to a chambered one.
Old Nov 23, 2014 | 08:18 AM
Default Exhaust
Ok thanks, what muffler do you recommend and I am looking for something asap so probably looking at advance auto or pep boys lol
Old Nov 23, 2014 | 10:29 AM
91parkave's Avatar
Moderator
Are you still all the way stock on your exhaust? Yea the whole rear portion is restrictive as well the portion right after the cat. All in all theres not much good about the stock exhaust.
Old Nov 23, 2014 | 10:39 AM
Default Exhaust
Yes all stock except the no cat 3"dp...check my other thread I just started for dyno numbers
Old Nov 23, 2014 | 01:34 PM
GXP25's Avatar
I could also use some exhaust information.
Like what style mufflers (offset, etc.), tubing, headers, etc.
Old Nov 24, 2014 | 08:49 AM
blkchevyz's Avatar
i put this on mine.
http://www.mandrelexhaustsystems.com...ND-PRIX/Detail
i went with 3 inch, and put some knock off flowmaster mufflers on it. a little loud for me, but sounds good.
Old Nov 24, 2014 | 08:58 AM
blkchevyz's Avatar
another setup i had prior to that, i put a small 1 chamber single in dual out muffler in place of the y-pipe and just made need tail pipes. sounded good and was cheap lol
Old Nov 24, 2014 | 09:38 PM
supercatxr7's Avatar
Unhappy
Originally Posted by blkchevyz
i put this on mine.
Not a bad deal for all mandrel bent. Did you go with stainless? How was the fit and quality. You went with 3", what does the two rear exits taper down to at the rear? Did they maintain 3" there as well? Only reason I ask is that I have a ZZP set up on my MC SS and although it is a 3" center section, it tapers down to 2.25" for the two rear exits....
Old Nov 26, 2014 | 10:17 AM
Ackbar00's Avatar
Just buy my Flowmaster I have for sale
Old Nov 28, 2014 | 08:29 AM
blkchevyz's Avatar
no i didnt go with stainless. the quality was good, fit i had some issues but thats was probably me more then them. just had issues getting everything strait but doing it on my back in my garage didnt make that easy, plus i did a 3 inch downpipe at the same time.
it stays 3 inch all the way. 3 inch to the y, then 3 inch out it. so you need 3 inch mufflers as well.
Old Nov 29, 2014 | 08:58 AM
GXP25's Avatar
The hangers were all there as well?
Also, where does this connect to? The catalytic converter?
Old Dec 1, 2014 | 08:29 AM
blkchevyz's Avatar
yeah it hand hangers but they have to be welded on. yeah it hooks in right after the cat. i did a 3 inch downpipe at the same time so i cant tell you how well it mounts to stock.
it basically came with everything but mufflers and tips.
