Coilovers monte carlo SS
Old Dec 24, 2014 | 12:19 AM
Sint3k's Avatar
Default Coilovers monte carlo SS
Ok , so i found some instructions on how to make coilovers. I was going to go with KYB AGX but when i received them in the mail one of the shocks was completly busted and had failed so i returned all 4.
I've had complications understanding what is what with all the bilstien HD , comfort VS AC Delco part numbers , VS GM part numbers.
Whats anoying is GM list the same part numbers for LS/LT/SS 2002,2003,2004,all the way to 2007 as the same part numbers which i find hard to beleive.
So what is the REAL part # of the FE4 Suspention on the 06 monte carlo SS's for just straight exact replacement
Links to wherever you find this would be awesome , i'm pulling my hair out with all this bull i wish bilstien would just make the HD's again.....
Old Dec 24, 2014 | 09:27 AM
91parkave's Avatar
Moderator
Use grand prix comp g shocks for delco fe4 shocks. Which coilover guide did you go off of mine? What other help did you need ?
Old Dec 24, 2014 | 09:41 AM
Sint3k's Avatar
I found some other threads off of the one you posted, I'm not sure if we are talking about the same thread but i dont remember being a mention as to which strut you used exactly,
I'm assuming you meant
Front: 505-548
Rear: 505-549
as these are what ive found for the GXP's
Anyways , Thanks as usual your always first to respond. I got everything in to put the coil overs together so i'm sure i'll be asking more questions, just need the strut now.
Old Dec 24, 2014 | 09:45 AM
91parkave's Avatar
Moderator
Front: 505-548
Rear: 505-549
You get your mounts put together yet?
Old Dec 24, 2014 | 09:47 AM
Sint3k's Avatar
I ordered mounts from rock auto so i didnt have to use the ones that are on the car now , and no i havnt , was i correct in my previous post that those where the correct part numbers for the gxp shocks that you used?
Old Dec 24, 2014 | 09:57 AM
91parkave's Avatar
Moderator
Those are correct but out of stock again. As far as the mounts go you know modification will be needed right?
Old Dec 24, 2014 | 10:00 AM
Sint3k's Avatar
I saw how there where 3 diffrent kinds and some required grinding ect. Right now im just working on the rears and finding a way to weld on the side peice of metal for the sway bar , i have a arc welder , but ive only used it a few times with very ugly welds lol
Old Dec 24, 2014 | 10:04 AM
Sint3k's Avatar
What rear spring rate are you using ?
Old Dec 24, 2014 | 01:11 PM
91parkave's Avatar
Moderator
Youll want 400lb on the front 300-350out back
Old Dec 24, 2014 | 04:17 PM
GXP25's Avatar
For some clarification:
Originally Posted by GXP25
Just to be clear, there are three different models: B6 (C) Comfort, B6 (HD) Heavy Duty, and B8 (SP) Sport.
OEM GXP Bilsteins are tuned by GM and fit in between the B6 (C) Comfort and B6 (HD) Heavy Duty. I believe most people go for the HDs.
B6 (C) Comfort:
Front: 35-153375
Rear: 35-153382
B6 (HD) Heavy Duty:
Front: 35-153153
Rear: 35-153160
All can be found on Amazon and are pricey.
EDIT: I'll be going with the B6 (C) Comfort struts.
OEM GXP AC Delco part numbers:
Front: 505-548
Rear: 505-549
OEM Super AC Delco part numbers:
Front: 506-682
Rear: 506-664
