help: crank pulley wobble
Old Sep 4, 2015 | 02:22 PM
black_betty's Avatar
Default help: crank pulley wobble
so I was looking over my GXP today to make sure I will pass inspection next week and noticed something that threw a red flag to me. at idle my crank pulley looks to have a pretty noticeable wobble while turning. checked with a bar to see if it moved while the engine was off and nothing. the engine runs smooth as silk and has no vibrations... anyone have a clue? or anyone else had this happen as well?
Old Sep 4, 2015 | 08:10 PM
rottonj's Avatar
Not sure but I found a couple of similar older posts so it could be common. Video on Youtube.
http://www.gmls4.com/index.php?topic=2014.0
https://ls1tech.com/forums/ls4-perfo...placement.html
Old Sep 5, 2015 | 06:52 AM
yeah looks the same but mines worse than that.
Old Sep 5, 2015 | 10:03 AM
91parkave's Avatar
Moderator
Time to replace. Really easy job to do provided the right tools. Should take no more than a hour to be honest
Old Sep 5, 2015 | 10:06 AM
rottonj's Avatar
I thought I read that bolt has to be torqued to 240ft lbs. That has to be a mother unless that motor is out. That is standing on a pipe torque.
Old Sep 5, 2015 | 10:14 AM
91parkave's Avatar
Moderator
Have the car high enough with a pipe it's easy that extra tty portion will kill you though lol
Old Sep 5, 2015 | 03:57 PM
spawne32's Avatar
Or having an impact gun that does 650 ft lbs lol
Old Sep 5, 2015 | 04:47 PM
well the stock one is like 180 on rock auto... I wouldn't imagine they make a performance one that's maybe lighter or more durable. is that a good price for a balancer?
Old Sep 5, 2015 | 06:53 PM
rottonj's Avatar
Just google that part number and check eBay as well , you are supposed to replace that balancer bolt as well.
Old Sep 5, 2015 | 07:14 PM
rottonj's Avatar
You have a side job changing dump truck tires ?
Old Sep 5, 2015 | 11:19 PM
spawne32's Avatar
lol i dont believe in buying cheap tools :x
Old Sep 6, 2015 | 06:59 AM
so far amazon is cheapest for the pulley at about 155. thanks guys.
Old Sep 6, 2015 | 07:34 AM
rottonj's Avatar
No wonder that car doesn't fit in the garage, your compressor must be huge lol!
