Will bad LCA bushings cause an occasional clunk?
Just throwing parts at isn't the fix, you need to check everything.
Jack up the front end, put on stands, get a good flashlight or drop light, a pry bar, and start checking things.
Sure you may find it eventually, but won't be cheap.
These can be hard to find. Figure out how to recreate the noise without driving it. Like Forward and Reverse with brake on. Add throttle.
Put the car in Park and rock it forward and back. Steering left and right.
