K&N Aircharger
K&N Aircharger
On the website they have one listed for 2006 - 2007 Impala 2006 - 2007 Grand Prix but only the 2007 Monte Carlo. I sent them an email and they sent me this generic response saying that if it isn't listed on the website it wouldn't work. I don't see why it wouldn't fit. I just wanted to make sure and see if someone installed it in a 2006 Monte Carlo.
IVe got the K&N kit installed on my SS. I love it! much quicker throttle response, a slightly noticable boost in power, and a sweet sounding growl
I Had to bend the corner (towards the headlight) of the bottom plate that the ECM bolts to as it was hitting metal ang wouldnt fit quite right. Has anyone else ran into that?
Make sure to keep an eye on your shifting now that you've got a K&N in there. Regardless how light the factory oiling was, it will contaminate your MAF and cause wierd shifting after a while. You'll eventually need to clean your MAF to clear the problem.
Has anyone thought about taking some light compressed air and blowing out some of the excess oil from the filter before installation? I have done this in the past without problem and have had no problems with transmission shifting issues with other cars....
Jason
Jason
LS1Tech Sponsor
I just checked and cleaned my MAF the other day, after having my CAI intake on for at least 9 months now - it's got a 9" K&N cone filter in it... and my MAF and TB intake hose were still clean, no issues... but since I already had it off to check it, I cleaned the MAF anyway...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
LS1Tech Sponsor
oh NOW you tell me...
no, I didn't even think about that, since I don't usually log the MAF values anyway...
__________________
I thought about it since the GM bulletin advised the tech to compare the MAF values of two vehicles and if they are different, NOT to warranty the repair. I plan on logging mine when the temps to go up and the Sun dries everything out to see if it makes a difference.
LS1Tech Sponsor
well, since a CAI and the K&N filters have more airflow than a stock setup, of course the values would be different anyway, right?? that's not a good/fair comparison.
or would they put a MAF from another car into our setup and compare??
I'm guessing that as long as the numbers are close, it'd be fine - cuz you're not going to get the same exact numbers from one car to the next anyway.
__________________
I'll have to go back and look at it, but I think they meant to compare and if the values were lower on the oiled MAF it indicated a messed up MAF.
I'm going to log it anyway so I can see what it really does after a cleaning.
